It is currently Sat Oct 20, 2018 6:41 pm
 Post subject: Need a new MB
PostPosted: Tue Dec 14, 2004 6:37 am
My mates pc has completely died and I need a new MB. Problem is he cant afford to go out and replace cpu, ram vga so I need a board that will support a Duron 1200, pc133, onbord sound,vga and lan if poss. Any ideas coz i am stuck ? :?
Davvo
PostPosted: Tue Dec 14, 2004 6:53 am
Davvo I really dont think youll find anything "new". Your best chance is to look for a used motherboard in sales or auctions.
PostPosted: Tue Dec 14, 2004 8:10 am
If you're ok replacing the RAM you might be able to fit the rest in a new board.. but now you're starting to inch closer to the price of a full computer build anyway... Save the case and I/O cards and build a new computer IMO ;)
PostPosted: Tue Dec 14, 2004 8:15 am
RAM is not that expensive. My vote would be to get this
http://www.newegg.com/app/ViewProductDe ... 160&depa=1
and then this memory stick since the board needs DDR
http://www.newegg.com/app/ViewProductDe ... 001&depa=1
Total comes to about: 81.18
I know he probably doesn't want to spend a whole lot of money, but then again you have to spend a tad if you're dealing with PC's. Companies are out to make a buck.
I selected the best I could for you and looked at the price as well. Hope this helps.
In process of building a new machine
PostPosted: Tue Dec 14, 2004 8:21 am
MGT has the more sensible answer of course. I get a little over-the-top when people ask me to spend their money ;)
 Post subject: Re: Need a new MB
PostPosted: Tue Dec 14, 2004 8:24 am
Davvo
I tried to answer your question the best I could, but reading this again, you sure your cpu didnt die with the mobo ?
My brothers fan went out on him one day. Mobo was fine but the cpu was fried big time.
PostPosted: Tue Dec 14, 2004 8:43 am
i had that same board(ECS "K7VTA3 V6.0") it was the worst board ive ever used. random crashes daily. ECS means Extremely Crappy Stuff.
Abit VA-10 $53
PDP 256Mb pc2700 $40
$93 with shipping included. cheapest quality solution.
PostPosted: Tue Dec 14, 2004 8:47 am
Go with Cac's solution
PostPosted: Tue Dec 14, 2004 8:53 am
Just so you know, first of all the pc wouldnt boot as the bios didnt detect the hd. Then after resetting bios it booted but crashed and wouldnt reboot couldnt see hd again in bios. Put hd on my pc and was detected ok. Put back in original pc then no output to monitor and wont post, no beeps just fans and lights. Tried two good cpus and various sticks of ram still no post ????
Davvo
PostPosted: Tue Dec 14, 2004 9:00 am
tried another power supply?
