It is currently Tue Jan 22, 2019 3:58 pm
Which Barton
2400+ 35 w Mobile 63%  63%  [ 5 ]
2400+ 45W Mobile 0%  0%  [ 0 ]
2500+ Mobile 13%  13%  [ 1 ]
2600+ Mobile 0%  0%  [ 0 ]
2500+ 0%  0%  [ 0 ]
2600+ 13%  13%  [ 1 ]
other 13%  13%  [ 1 ]
Total votes : 8
 Post subject: Which Barton?
PostPosted: Mon Nov 29, 2004 9:54 am
I have the Soyo SY-KT600 Dragon Ultra Plat MB. Gonna buy a 512MB stick of PC3200 RAM. Now I just need to settle on the CPU. I've read so much I'm dizzy so this is gonna be it I think.
Here are my choices. Pleas tell me IYHO which is the best/easiest to OC.
Thanks
New Build in Progress
New Rig in progress
Soyo KT600 Dragon Ultra Platinum
AMD 2400+ 35w mobile IDYHA
ATI AIW 8500 128MB
Patriot 512 MB PC3200
WD 120GB, 40GB HD's
Cooling Thermaltake Extreme Volcano 12
PSW Thermaltake Silent PurePower 420W
PostPosted: Mon Nov 29, 2004 10:18 am
The mobiles are the easiest to overclock. The 2500 has typically been the most popular, but I'd prolly say the lowest wattage Barton will give you the most headroom. I haven't had personal experience with the low wattage ones, only a 2500 mobile.
PostPosted: Mon Nov 29, 2004 10:24 am
The mobile 2400+, 2500+, and 2600+ all max out around the same speeds.
I would suggest you get a 35w 2400+
I have the 45w version and its a great CPU.
PostPosted: Mon Nov 29, 2004 10:46 am
Be warned if you overclock you void warranty
I would never recommend overclocking anything unless you are a seasoned user and prepared to take the risk.
Many here are overclocking Holics does not mean to say we should all do it.
I would go for a 3200+ Barton core it has the 400 FSB and is the fastest XP processor there is....I checked your board and it seems to support it
http://www.soyousa.com/products/proddesc.php?id=256
IMO it makes best sense to go for this rather than overclock a lower spec processor....prices on XP processors are dropping and the money saved buying lower spec to the 3200+ is negligable
Benjamin Franklin (1706-1790)
PostPosted: Mon Nov 29, 2004 11:20 am
yah but the 3200+ barton is still 200 bucks as opposed to the 35w 2400+ mobile that's only 85 bucks. and everything i've read has said that all of the mobiles easily overclock past 3200+ speeds.
PostPosted: Mon Nov 29, 2004 12:05 pm
Its extremely easy and not an issue when overclocking to atleast 3200+ speeds. The CPU wont even break a sweat. There is little to no voltage increase at all when clocking at 3200+ speeds.
As long as you dont push the CPU too far, you will be fine.
I have been overclocking for a while and I havent blown or fried anything yet (and I have done some pretty stupid stuff).
The 3200+ barton is NOT worth the money compared to a mobile 2400+ if you are willing to overclock.
PostPosted: Mon Nov 29, 2004 12:43 pm
As stated overclocking voids warranty
3200+ has a 400FSB I doubt an overclocked lower CPU (clocked to 3200+ speeds) would be as fast or stable as the 3200+ probably burn out faster too.
PostPosted: Mon Nov 29, 2004 1:57 pm
Set the Vcore to about 1.55 and treat it just like a XP3200 , it will never know the difference .
E Pluribus Unum
PostPosted: Mon Nov 29, 2004 2:03 pm
Who said he is going to stop at 3200+ lol. :lol:
PostPosted: Mon Nov 29, 2004 2:05 pm
The 35 watt 2400 is such a great CPU. I just wish I had better cooling and a little mor voltage because I could easily hit 2.6 ghz. With some good water cooling I think 2.8 is reachable and maybe even higher. Get a 35 watt if you can still find them.
- MSI K7N2-L
- Mobile 2400+ 35w @ 2.5 ghz
- 1024DDR Geil 3200
- HIS ICE Q 9800Pro
- (452/752 mhz w/R350-Samsung 2.86)
- WD SE 120 gig
- TDK burner & Hitachi DVD
- Audigy 2 ZS & Leadtek TV2000XP Deluxe
