Where to get Slocket...
Does anyone know where I can get a slocket? I would like to get one to upgrade my comp, but I can't seem to find them anywhere!
Tono Sien
Love is the greatest conspiracy, by the most loving genius.
Check out http://www.evergreennow.com/category.cfm?Category=10? but the prices may make a new MOBO and CPU, while a little costlier, a better choice. I have a Slot A Athlon that I've never upgraded with a slocket simply because the boards were better value.
If it doesn't fit, force it. If it breaks, it needs to be replaced anyway!!
- jronald
- Black Belt 1st Degree
Look Here
http://www.tigersurplus.com/
Halfway down the page. 2nd Item under MOBOS
These guys are not fancy, but after several buys they have been outstanding. You Need Java to work!
"With this adapter, your older Slot 1 motherboard can reach new levels of performance! Our tests with several motherboards showed this adapter to work well in allowing the board to run a Celeron and a Pentium III Socket 370, both FCPGA & PPGA processors! These are short in supply and wont last long."
Ron
Ron
My son carries in his childhood, the wonders I have sought my lifetime to find, and squandered fortunes to posses
- Brown Belt
www.compugeeks.com also has them
Folding folding folding keep them procs a folding.......
P4 2.53 ghz @ 2.86
P4 2.53 ghz @ 2.86
- Initiate
Do you mean http://www.compgeeks.com? The link you posted doesn't work for me.inteljunky wrote:www.compugeeks.com also has them
[email protected] Fighting diseases every second. Join us! https://foldingathome.org/
