It is currently Sat Feb 29, 2020 2:38 am
 Post subject: laptop Screen
PostPosted: Sat Jul 06, 2019 12:37 pm
About 4 or 5 years ago I bought another Sager laptop (Clevo) for home computer use (no gaming). The computer at the time was built for performance and it performs very well and still does. At the time it was new I had a problem with the screen and sent the pc back. They put on an IPS LED matt screen which looks great but I would rather have had a glossy screen which I could not get at the time.
My question is now 5 years later is there a better type screen available than what I now have? I do believe the TN type screen is better for angle viewing but that is not an issue with my use of this laptop, the pc stays in the same position all the time. My concern is the best robust and brightest display and would prefer a glossy screen if I could get it. I probably would not change the screen that is on it now but would consider something newer even though this i7 SSD pc is running fine.
Thanks
KEEP AMERICA GREAT
 Post subject: Re: laptop Screen
PostPosted: Thu Jul 11, 2019 1:58 am
I am slightly confused on the actual question.
You are looking for a new laptop with a glossy screen? Is that general-purpose or as a replacement for the Sager/Clevo?
PostPosted: Thu Aug 08, 2019 5:33 pm
We would need to know the model and configuration of the unit to help you further with this.
Kind Regards,
AJ23ZX
PostPosted: Mon Sep 02, 2019 3:46 pm
Was wondering what the best performance type screen there is today for a laptop? Also liked the glossy screen seems more robust with the colors?
KEEP AMERICA GREAT
PostPosted: Tue Oct 15, 2019 7:22 pm
Have you tried contacting Sager for the spec details of your screen and their recommendations for replacement glossy one?
