It is currently Sat Feb 29, 2020 2:45 am
PostPosted: Wed Feb 27, 2019 4:05 pm
Wellsir ... what was suppose to be a simple install of a usb card turned into a disaster. Long story short my AMD Rig is no more CPU shot. I suspect the usb port were going bad on the mobo. I have to replace it.
Here are the parts I will be replacing ... did the best my budget will allow.
Case
https://www.ebay.com/itm/DIYPC-Solo-...53.m1438.l2649
CPU
https://www.ebay.com/itm/AMD-Ryzen-7...53.m1438.l2649
Motherboard
https://www.ebay.com/itm/MSI-B350-TO...53.m1438.l2649
Memory
https://www.ebay.com/itm/16GB-Kit-2x...53.m1438.l2649
I'll be using the same video card and dvd players and power supply from the old rig. This will be much faster than my main rig when I get it together. Let me know what you think. I didn't see anything to indicate the mobo is not compatible with windows 7. I hope I will be able to format the C drive on my other computer so I can use it again on this new rig.
Main Rig_Intel i7 4770k@3.50
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
WD100000 SATA 7200RPM
Seagate 1TB SATA 7200RPM
Corsair CX750M
Win7 Ultimate x64
Rig2_AMD Ryzen 7 1700
MSI Gaming B350
16Gb DDR4 2133
ZOTAC GeForce GTX 550TI
Seagate BarraCuda Pro 4TB SATA 7200RPM
Inland 600 P/S
Win7 64
PostPosted: Thu Feb 28, 2019 1:30 am
All links are broken because they are shortened, not much to check. Can you give make and model of what you are buying?
PostPosted: Thu Feb 28, 2019 9:27 am
https://www.ebay.com/itm/AMD-Ryzen-7-1700-8-Core-Desktop-Processor-Socket-AM4-w-Wraith-Spire-LED-Cooler/183569847601
https://www.ebay.com/itm/16GB-Kit-2x-8GB-DDR4-2133MHz-PC4-17000-288-pin-DESKTOP-Memory-Non-ECC-2133-RAM/362480439084?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
https://www.ebay.com/itm/DIYPC-Solo-T2-BK-Black-USB-3-0-ATX-Mid-Tower-Gaming-Computer-Case-with-2-x-Blue/302879310177?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
https://www.newegg.com/Product/Product.aspx?Item=N82E16813144047
I checked the links this time. With my luck you will see me back when it is time to put this rig together.
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
Win7 Ultimate x64
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
Win7 64
PostPosted: Fri Mar 01, 2019 9:19 am
The question mark is the memory. Not knowing what brand/model it is might hold a surprise. There's a reason for this list:
https://www.msi.com/Motherboard/support ... ort-mem-12
We'll see. Let us know.
PostPosted: Fri Mar 01, 2019 11:31 am
Don't worry ... you will be seeing me back here by the end of next week. I got that memory because it had a lifetime warranty so I figure it will be ok. Hopefully it will work with no problems. :-|
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
Corsair CX750M
Win7 Ultimate x64
MSI Gaming B350
16Gb DDR4 2133
Inland 600 P/S
Win7 64
