It is currently Thu Jan 23, 2020 9:57 pm
PostPosted: Sun Apr 15, 2018 10:07 pm
I have a Samsung Galaxy S7 and want to use a desktop APP on Windows 7 to sync and make updates to when I am in front of my PC...
Any suggestions??
(PC Specs)
CPU: AMD FX-9590 4.7GHz 8-core
CPU Instructions: MMX(+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
Motherboard: Asus SABERTOOTH 990FX R2.0
GPU: nVidia GTX 1070 Ti 8GB
GFX Drivers: Nvidia v431.60
OS: Windows 7 Ultimate 64-bit SP1
RAM: 32GB Kingston 1866MHz DDR3
PostPosted: Mon Apr 16, 2018 8:29 am
Maybe Samsung and others already thought of that?
Most smart phones and tablets use the Android OS.
But go with known and trusted sites, so you don't get any "wormware" and 'loggers'.
https://www.samsung.com/us/sidesync/
https://en.softonic.com/downloads/andro ... /windows-7
PostPosted: Mon Apr 16, 2018 8:35 am
Hey Karl, ok I will check them out when I get back online in a few minutes...
Doing the restart to update my audio drivers, Realtek sucks in this one regarding
Uninstall old ones Auto restart install new ones Auto restart
Oh what a bother the developers need to get their heads out of their asses
(PC Specs)
PostPosted: Tue Apr 17, 2018 10:57 am
It is that way with a lot of programming, especially OS associated features!
Maybe the primary reason is to flush the RAM and refill new, with all the old drivers and DLL links gone.. then repeat with the new links. Some apps and features can associate with more than 10 DLL links to be useful!
Gone are the days when an OS needed only 2 megs or so of system memory. Today, even 4 gigs may not be sufficient, with all the bloatware!
There are hundreds of apps to link different formats and devices.. but you want one that is reliable and doesn't hang you out in the "hunting fields" for hackers, especially public WIFI sites! Even home WIFI setups are very vulnerable to hackers unless locked down with complex passwords. The best and safest "link" between devices is the old-fashioned hard wire!!
PostPosted: Tue Apr 17, 2018 11:28 am
my passwords are so complex as to be HACK PROOF and Mwhahaha and I use MAC filtering so hacking is impossible... anyway...
The Samsung SideSync might do the trick... but that does everything the phone is doing...
(PC Specs)
PostPosted: Tue Apr 17, 2018 12:41 pm
nothing is impossible to hack...it's simply a matter of expending the time, energy, money, technology and knowledge to accomplish it. if somebody considers those things and determines it "worthwhile" to hack it, it'll be hacked eventually.
besides, MAC filtering is practically useless for network security. it's really only useful for management of devices. might as well just open up a guest network with no security for those you want off your "main" network. :wink:
-R
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Tue Apr 17, 2018 12:44 pm
I have MAC filtering set to disallow ALL but the ones I say ok to manually entered into the router...
(PC Specs)
PostPosted: Tue Apr 17, 2018 1:20 pm
MAC (and IP subsequently) spoofing is covered in first semester network security - MAC addresses traverse unencrypted and once known an intruder can spoof it and be on your network just like the device they've spoofed from.
PostPosted: Wed Apr 18, 2018 7:39 am
No filtering such as MAC, WPA or other form is really "hack-proof". Even a VPN with level 3 security is still a risk.
With modern algorithms on a search machine, hundreds of combinations can be tried in minutes. One safer means is a 3-time try lockout for that unauthorized IPA for at least 12 hours. Most financial institutions have this feature, and any more tries for access are blocked. Then you may have to call them for a temporary security clearance password!
