It is currently Wed Aug 15, 2018 3:23 am
Post new topic Reply to topic  [ 12 posts ]  Go to page Previous  1, 2
PostPosted: Mon Sep 26, 2016 3:55 pm
hold on... 5 Gigabit/s = 5000 Megabit/s correct?
divide 5000 by 8 and you get 625 MB/s.
https://www.google.com/?gws_rd=ssl#q=5+ ... %3F+MB%2Fs
right? of course I understand this is all theoretical, and you usually only see half that in real world use.
I know most hdd's only do up to around 200 MB/s, MAX, and that's a really good one at sustained speeds over a long run... ssd's are much better, mostly getting into the high 300's, sometimes more depending on what's feeding it.
in any case... can a usb type-a connector transfer anywhere near this high?
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
PostPosted: Thu Oct 13, 2016 5:15 am
to continue this thread, I installed the card I linked earlier...
http://www.sybausa.com/index.php?route= ... Y-PEX20203
I hope another better card comes along, as the drivers for this one a little finicky to install. had a couple blue screens on installation/uninstallation.
but it seems stable enough after install. I got transfers from one usb3 ssd device going from the intel usb3 ports native to the motherboard thru to this card and out to another usb3 ssd at 250 MB/s sustained, which is not bad.
don't have anything to plug into the type c connector right now, so nothing to test there.
haven't done crystaldisk benchmark yet.
my main rig...
asrock 970 extreme3
antec neo he 650r
