Which motherboard would be good for my setup
Postby Aiwa » Sat Jul 09, 2016 3:56 pm
Basically I have a GPU sitting around in my house that is not compatible with my motherboard (my motherboard is very old and uses different BIOS). Basically I want a motherboard that is compatible with my setup and that it will be compatible with my new GPU
My setup are as follows:
(Current) Motherboard - Pendragon 2AC2 (AMI BIOS)
CPU - i3 2100
RAM - DDR3 8GB
GPU - GeForce 530 (I have a gtx 750ti that's waiting for me to buy a new motherboard)
If anyone can recommend me some motherboards to look at that would be compatible with this setup it would be much appreciated. I understand I will have to buy a power supply as well and most likely a case, and I will look into that once I have an idea of a few options for a motherboard. Also I would prefer if it was in a mid-range price.
Thanks in advance
Aiwa
Re: Which motherboard would be good for my setup
Postby evasive » Sun Jul 10, 2016 12:28 am
Carmel board made by Pegatron for HP
http://www.ctechinfo.net/motherboards/p ... carmel.php
That is standard microATX so anything with that form factor will do.
What is your budget for the power supply and the board?
Return to Recommendations
