Hi guys, hope you can help me.
I bought a pc of Ebay last year and didn't look into MB specs.
Guy wont take it back as so long now but I have a problem.
Pc only has one dvd bay, 1 ssd bay and 2 satta HDD bays, no case cooling but for rear fan, power supply on floor, pushing hot air onto R7 240 graphics,
and it has AMD FX8350 4Ghz 8 core CPU. 16 Gig ddr3 ram, not sure on speed but Crcial says its pc 12800.
( http://uk.crucial.com/gbr/en/scanview/6960786C31D926C3 )
MB is Gigabyte 78LMT-usb3 ( http://www.gigabyte.com/products/produc ... id=4305#ov ) Running windows 7
All this in a small ATX case and overheating to quickly, now getting Blue screen of death
Hoping to get another MB which has fan connections so I can plug more than 1 fan into it, and a case to fit which will allow at lease 3 hard drives and 2 + front bays.
I know its asking a lot but need to allow it to cool but cant carry on with noise of fans running at max with no control and all the heat building up, have to run with side of case removed at moment. not good when you have 2 year old daughter that likes to explore my office!!!
Hope you guys can help....
Many thanks
