It is currently Sat Oct 20, 2018 3:38 pm
PostPosted: Tue Jun 16, 2015 7:48 am
I want to add an additional internal drive to my desktop machine. I have done this in the past with IDE MASTER/SLAVE hard drives, but I have never added a second SATA drive (SLAVE) to a machine where the PRIMARY drive is also a SATA.
My MB is Intel DQ35JOE
Currently, the hard drive installed is a SATA and the data cable connects to 1 of the 5 available Serial ATA Connectors.
This board has 1 IDE connector which is being used by the internal DVD writer
I am thinking that with this MB it is permissible to connect a 2nd internal SATA drive and plug it into one of the 4 remaining Serial ATA Connectors, and then just power the drive with one of the unused power cables.
Does this sound logical?
If so, would the SLAVE SATA drive need to have jumpers changed (similar to what I do when an IDE drive is added as a slave?)
Any Advice Greatly Appreciated
Antec 900 - 650W ATX
Intel DQ35JOE
PC2-6400 DDR2-SDRAM UDIMM - 2x4 GB (Clocking 800mhz)
Primary: SATA 3gb/s - Hitachi HDP725050GLA360(500 gb)
External-USB: SATA 3gb/s - WDC-WD7500AACS-00ZJB0 (750 gb)
Microsoft Windows 7 Home - SP-1
PostPosted: Tue Jun 16, 2015 9:46 am
no jumpers required - when you first boot it'll probably use the existing drive as the boot one still - and the other will just be automatically recognized and found in windows. this is the most-likely case.
if you get an error at during boot up about no bootable disk found, just restart, go into your BIOS and change the hard disk boot order, putting the "old" drive higher/to the top - save and restart, should boot right up.
SATAs are beautiful in this respect...no physical fiddling once it's in there.
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Tue Jun 16, 2015 10:02 am
Thanks
One other question please.............looking on line at 2T size drives...........does it make a difference is the drive SATA I, II, III ???
Intel DQ35JOE
PostPosted: Tue Jun 16, 2015 10:36 am
they're just progressively newer standards. 2 is faster than 1 and 3 is faster than 2...
along with the higher number will typically come higher prices. I haven't seen the need (or desire even yet) to go to SATA-III. it's just not something I've seen a need for. I had a SATA-I SSD back in the day, and while I'm sure there's benefits to the SATA-II's I have now, I don't really notice much real-world difference. your mileage may vary though, depending on how you use your computer.
in order to get the benefits of SATA-III, you need to have a SATA-III port on your machine, whether directly on the motherboard(which I think yours is too old to have) or through a PCI-E expansion card.
-Roach
PostPosted: Tue Jun 16, 2015 10:39 am
ahhhh...........ty
Intel DQ35JOE
PostPosted: Tue Jun 16, 2015 11:42 am
One thing you have to take into account when U add a new sata HDD is to look in the bios setting so that the port U are using is set as Legacy or Native (preferred) because if the port is set as RAID u have to install the RAID driver for the motherboard before U can use the new HDD, on anyway the RAID setting is only useful for special purposes
the red sata conector is an external SATA conector (eSATA)
-Wrapped Around Your Fingers-
-The Police-
PostPosted: Tue Jun 16, 2015 3:26 pm
The SATA III devices are supposed to be backward compatible to SATA II controllers.. but reduced data speed will be noted. There may be a jumper on the drive to set the status for SATA II or III standards.
Should be no problems with a larger secondary hard drive, but the BIOS date may affect capacity, if a primary drive. If not accessible, do a partitioning as required.
Set the BIOS for SATA to "auto" or "JBOD" instead of any RAID configuration. Port "0" should be the primary hard drive, and Port "1" should be the secondary.
Some links as to reference on that DQ35JO "E" board..
http://downloadmirror.intel.com/15038/e ... nglish.pdf
http://downloadmirror.intel.com/15038/e ... odSpec.pdf
