Intel DQ35JOE
Intel DQ35JOE
Postby meppwc » Mon Jun 15, 2015 4:24 am
I have an Intel DQ35JOE MB
I am using a nVidia GeForce 8800GT which has failed. (Device Manager: PCI Slot 11 (PCI bus 1, device 0, function 0) - This device cannot start. (Code 10).
I am guessing that there might be better video cards out there that will work on my MB. Can any offer suggestions?
Antec 900 - 650W ATX
Intel DQ35JOE
PC2-6400 DDR2-SDRAM UDIMM - 2x2 GB (Clocking 400mhz)
Primary: SATA 3gb/s - Hitachi HDP725050GLA360(500 gb)
External-USB: SATA 3gb/s - WDC-WD7500AACS-00ZJB0 (750 gb)
Microsoft Windows XP Professional Build 2600 - SP-3
meppwc
Re: Intel DQ35JOE
Postby Karlsweldt » Mon Jun 15, 2015 5:22 am
Some specs on that video card..
http://www.geforce.com/hardware/desktop ... ifications
It is a PCI-E design, not the older PCI type. It does have auxiliary power sockets, and requires a dedicated lead set from the PSU. May require one or both 6-pin and 8-pin sockets connected.
Have you checked the BIOS pages as to first option for video? Should be PCI-E. Can you even get into the BIOS pages?
There may be a power LED on the port side of the card, which is red if not working, green if all is good. What is the status?
Remove and reinstall the video card. Vibrations or heating/cooling cycles may have caused the card to come partially out of its slot.
I had two (BFG) GFX280 1m PCI-E cards fail when doing F@H processes. Seems some brands do not provide adequate heat transfer from the GPU to keep the core below "meltdown". The current (EVGA) GTX460 1m is doing great after many months!
If noting distortion of video or odd color shades, likely the GPU has suffered a "heat stroke". Try another video card to check if your motherboard is still in good health. Look over the capacitors on the motherboard, if any have domed tops, lean excessively or show signs of leakage, they are bad. More info at www.badcaps.net/
While this posting is not a duplicate of your other one, it is very similar. Try to keep all info in one posting.
Re: Intel DQ35JOE
Postby meppwc » Mon Jun 15, 2015 6:02 am
Thanks so much for all recommendations. Note, I took the card out, blew it off and re-installed it. The systems booted up fine and found the card. Seems a little strange, but, whatever. Anyway, found some updated drivers from nVidia and installing them now. Note, I did not see a LED light on this card and the BIOS is setup for PCI-E
Hopefully all will go well...........and thanks again
Intel DQ35JOE
meppwc
Re: Intel DQ35JOE
Postby Karlsweldt » Mon Jun 15, 2015 3:10 pm
If the problem repeats, then likely the GPU or another component has suffered some heat damage. Hope it is still good.
You may want to check this link comparing your GeF8800GT against my GTX460.
http://www.hwcompare.com/8197/geforce-8 ... e-gtx-460/
I would recommend a 1 MB video card, more pixel "pipes" for faster image display. And a video card with a dedicated exhaust port will run cooler than one that exhausts into the cabinet!
Return to Recommendations
