Need mobo that can run 2 PCIE3 x16 GPU and 1 pcie2 x8 SSD
Postby donkimizer » Wed May 06, 2015 5:27 am
Hi.
I am planning to buy 2x Titan X cards and one Mushkin Scorpion Deluxe 1.92 TB SSD that runs on PCI-E 2.0 x8 interface together with some CPU that supports 40 PCI-E lanes. I am not sure which motherboard to choose, it will be both for work and gaming (maybe some OC but nothing too enthusiastic). I would prefer not to lose peformance because GPUs drop from X16 to x8 because too many taken PCI-E slots, and ofcourse all 3 components must fit :). Is rampage V extreme good choice?
Thank you.
donkimizer
Re: Need mobo that can run 2 PCIE3 x16 GPU and 1 pcie2 x8 SS
Postby evasive » Wed May 06, 2015 11:09 am
It reports x16/x8/x8, not x16/x16/x8 so no, this board cannot do what you are planning even with a 40-lane CPU. I would need to check the X99 chipset specs to see if it can use this configuration even.
Postby donkimizer » Wed May 06, 2015 12:00 pm
X99 E-WS and X99 deluxe seems to support X16/X16/X8 but i am not sure from specs if they support only Xeon processors or i7 too, because i was planning to put in a i7-5960x
donkimizer
Postby Karlsweldt » Wed May 06, 2015 4:03 pm
Asus X99 Deluxe CPU support: http://www.cpu-upgrade.com/mb-ASUS/X99-DELUXE.html
Asus X99E WS CPU support: http://www.cpu-upgrade.com/mb-ASUS/X99-E_WS.html
Sorry, had to take out one of your duplicate postings. For your intentions, may be better to go with a server board, dual CPU.
Postby evasive » Wed May 06, 2015 8:04 pm
Return to Recommendations
