It is currently Sun Jan 20, 2019 11:57 am
Post new topic Reply to topic  [ 11 posts ]  Go to page Previous  1, 2
PostPosted: Wed May 06, 2015 9:30 am
I love open source, so Linux is ok... I just don't like the base UNIX architecture its based on ;_;
but it lacks much, for instance well running GNU debugger (MinGW) via a file type association to load VLC Media player though the GDB while it loads any one avi/mp4/flv/etc file... the gdb window is not running through windows cmd.exe, so it lacks the following..
  • Scroll wheel support so having to manually mouse click the scroll up/down buttons.... <_<
  • no right-click context menu for copying/pasting text onscreen, user has to go to the root menu to do it
CPUz Reports:
Desktop (old LAN center gaming rig)(WinXP Pro x64)
http://valid.canardpc.com/fakxfs
Laptop (2008 Toshiba)(Win7 Ultimate x64)
http://valid.canardpc.com/vfz8pk
both are Intel Pentium D, so neither support virtualization.
_________________________________________________________________________________________________
so Windows 7 Professional x64 it is....
with the programs, Types(File Types) and Agent Ransack (File search program)...
two of the functionality problems are solved....
(PC Specs)
CPU: AMD FX-9590 4.7GHz 8-core
CPU Instructions: MMX(+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA3, FMA4
Motherboard: Asus SABERTOOTH 990FX R2.0
GPU: nVidia GTX 1070 Ti 8GB
GFX Drivers: Nvidia v416.94
OS: Windows 7 Ultimate 64-bit SP1
RAM: 32GB Kingston 1866MHz DDR3
Users browsing this forum: MegaIndex.ru [Crawler] and 3 guests
