Upgrade to Geforce GTS250 Graphics Card
Postby venom » Sun Feb 15, 2015 10:51 am
Hey Guys ater a cheapish upgrade to my 5 year old Geforce GTS250 graphics card, I've noticed it's really struggling if I'm on a webchat site like tinychat with up to 12 active video cams on at the same time. Any recommendations, My limit is about £100, how much of a power upgrade would I get for that ?
Thanks in advance.
venom
Re: Upgrade to Geforce GTS250 Graphics Card
Postby Karlsweldt » Sun Feb 15, 2015 4:44 pm
Decent specs on that GTS250.. http://www.geforce.com/hardware/desktop ... ifications
What is the wattage of your PSU? May be marginal, if video stutters. Max video power draw is 150watts.
May also not be a problem with the video card, could be a lot of background programs hogging data time.
Could also be time to do an internal dusting, or thermal limiting is starting due to high temperature in the case.
Postby evasive » Mon Feb 16, 2015 12:27 am
That would get you a GTX750Ti - ish which is 4 steps up on the ladder:
http://www.tomshardware.com/reviews/gam ... 107-7.html
But, as said, are you 100% sure it is your graphics card being slow, not disk throughput, lack of available memory or even your internet connection?
Postby venom » Mon Mar 02, 2015 6:54 am
Thanks for the input guys, spent a little more and decided to go for the 2GB Sapphire Radeon R9 270X TOXIC, 28nm, 5800MHz GDDR5, GPU 1100MHz, Boost 1150MHz, 1280 Streams, did I do good :) ?
http://www.scan.co.uk/products/2gb-sapphire-radeon-r9-270x-toxic-28nm-5800mhz-gddr5-gpu-1100mhz-boost-1150mhz-1280-streams-dport-hd
Im hoping for a good jump in performance.
venom
Postby Karlsweldt » Mon Mar 02, 2015 10:15 am
Impressive specs on that card, but it wants at least 180 watts of power. Hope your PSU is adequate.
http://www.sapphiretech.com/presentatio ... 2038&lid=1
Postby evasive » Tue Mar 10, 2015 11:43 am
2 extra steps on the ladder, yeah you should see improvement:
Postby Karlsweldt » Tue Mar 10, 2015 3:59 pm
Do a 3D Mark test on it, with no other background programming.. and compare test scores. :mb_happyspunk::
http://www.3dmark.com/
http://www.3dmark.com/hall-of-fame-2/
Return to Recommendations
