It is currently Thu Jan 17, 2019 3:09 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sat Nov 08, 2014 12:48 am
other than some real legacy programs, most of the software will run on 64bit windows as well. 64bit windows can handle 32bit software too. sometimes you will need to fiddle a bit. as for the hardware, seeing you are going to build a new system, it will run fine then.
PostPosted: Sat Nov 08, 2014 7:00 am
Quote:
What does "semi-dedicated F@H client" mean
The F@H process uses GPU hardware to do the dissemination and 'folding' of protein strains. Only when the system is idle, does the GPU program work. If any other user needs of the system, the process pauses. The previous F@H process was done with the CPU exclusively, and the program would use "spare" or "free" CPU cycles to do its work. Normal access to a PC was otherwise available.
PostPosted: Sat Nov 08, 2014 3:09 pm
Karlsweldt wrote:
One bit is either an on state or off state (yes/no) to control a process.
The computers of many years ago (1960s) were 4-bit class. This meant that a maximum data packet of 4 bits could be processed at one time. The early 1970s saw the first 8-bit processor. In the late 1970s the first 16-bit processor was available.
1981 was the time when a 32-bit processor became available. Then the 64-bit processor arrived in early 2000.
If a system is limited to 32-bit processing, a 64-bit OS will not be fully effective.. the hardware and driver sets have to be compatible. For optimum performance with a 64-bit system, the programming has to be compliant. Most processors and systems today can accommodate a 64-bit OS install.
Here is a link to Intel® and other processor history.. http://en.wikipedia.org/wiki/List_of_In ... processors
Thanks Karlsweldt, that's most helpful and very informative, :D I have saved that page for future reference although I know some of that having programed Z80 and 6502 8-bit.
ASUS P4S8X motherboard.
Intel(R) Pentium(R) 4 CPU 2.53GHz Northwood.
3GB DDR.
Gigabyte ATI Radeon R9700 PRO Graphics Accelerator.
USB Modem for BB.
Maxtor 80GB hard drive.
52x CD ROM Drive.
Floppy Drive.
Microsoft Windows XP Home Edition.
PSU, 420 W, P4.
PostPosted: Sat Nov 08, 2014 3:16 pm
"need to fiddle a bit" :lol: classic!and I thought you guys here had no sense of humor :D
Thanks evasive,
That's what I wanted to know. So most/all current software is written for 64 bit machines?
3GB DDR.
USB Modem for BB.
52x CD ROM Drive.
Floppy Drive.
PSU, 420 W, P4.
PostPosted: Sat Nov 08, 2014 3:22 pm
:? :oops: I have no idea what all that means, sorry. :oops:
3GB DDR.
USB Modem for BB.
52x CD ROM Drive.
Floppy Drive.
PSU, 420 W, P4.
PostPosted: Sat Nov 08, 2014 4:51 pm
As evasive noted, your new system should have no problems with a 64-bit OS platform. It should have few problems with 32-bit programs, maybe a few might need a bit of "tweaking" or "fiddling" to work proper. But the compatibility mode is there for that purpose, if needed. Backward compatible but not forward compatible.
As to the F@H or Folding at Home program, it is a study as to why and how proteins fold to become viable.. or faulted. And if they fault, at which step in the folding process is the cause. Snippets or small protein bits are digitized into a workable file for your computer to disseminate and simulate the folding process. Most types of cancer, other afflictions are the result of improper folding of proteins. It is thought there are over 2,000,000 protein types in the average human body!
Read up on the project...
http://folding.stanford.edu/
http://en.wikipedia.org/wiki/Protein_folding
PostPosted: Sun Nov 09, 2014 1:18 pm
All current software is written in such a way it can run on 64bit machines. Some of it will also run on 32 bit machines but this is getting less and less.
PostPosted: Mon Nov 10, 2014 1:45 pm
not much differences between home and pro but here they ar...
Location-aware printing home - No , pro - Yes
Domain Join wizard home - Not included, pro - Included
Windows XP Mode home - Not supported, pro - Supported
Remote Desktop Connection Cannot use Remote Desktop Connection feature to connect to a PC that runs Windows 7 Home Premium.
Remote Desktop Connection works when trying to connect to a PC that runs Windows 7 Professional.
home - Backup and restore Backups to a different drive or DVD only, pro - Backup to a different drive, DVD or over the network
here's another list...
http://helpdeskgeek.com/windows-7/windows-7-versions/
basically you get a couple other things you prolly won't ever use with the pro and ultimate versions. do you plan on using a domain? do you need to run legacy programs in xp mode? do you do lots of remote desktop stuff? do you need to backup over a network?
newegg sometimes has win7 home licenses for about 80 bucks, 40-50 bucks more gets you the pro version. you should prolly just save your money and get the home version, unless you have a need for those things listed.
but ABSOLUTELY get the 64 bit version if your computer cpu is 64-bit! that is a given.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
PostPosted: Tue Nov 11, 2014 9:13 am
Neither???????
If it were me I would wait until around Christmas time when Windows 10 will possibly out.
PostPosted: Tue Nov 11, 2014 12:31 pm
Christmas...2015? they haven't even announced a release date(most likely to do this in April), and that's typically months before its actual RTM. he could get a preview version now i suppose.
windows 7 will continue to be supported for nearly another half-decade, 2020 to be precise.
if you don't have a driving need to have Windows 8, like owning a touchscreen...or needing software that only runs(or runs way better) on Win8...i would personally recommend sticking with Win7, any of the 64-bit flavor.
i'd buy slightly cheaper Win7, have very little learning curve, and then go Win10 when you feel the need/desire to...
the other option is to pay marginally more for Win8, learn it's nuances, then most-likely get pushed into Win10 by lack of real support of Win8 since MS is effectively abandoning that OS.
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
