New to PC stuff. need some help
Postby ROFLCOPTER » Thu Apr 25, 2013 5:29 pm
My pc right now runs games pretty well but some games its terrible on. It runs skyrim,minecraft,killingfloor,deadspace 3 all fine and on ultra but its terrible whenever i play dayz i usually get 17-30 fps on dayz but rarely ever get 30.
my current build right now is:
AMD A6 500k
AMD Radeon HD 7560D
RAM: 6gb
1T Harddrive
i am thinking about getting the
Galaxy - GeForce GT 640 Graphic Card(the 1gb DDR3).
will this help with games much more?
ROFLCOPTER
Postby Mr T » Thu Apr 25, 2013 9:17 pm
Welcome to the motherboards.org...
I presume you are using the video on the AMD APU and not a separate video card?
If so, then have you updated all your drivers, updated windows? If other games are running OK then the game itself is the issue and may need updating itself.
Postby evasive » Thu Apr 25, 2013 11:25 pm
Is that the mod for Arma 2 or the standalone version of DayZ that you are running?
Postby bdub » Fri Apr 26, 2013 9:41 am
what make/model psu you got? sometimes the branded systems will struggle if you put much more hardware in them than what they came with.
and i'd suggest this card over a 640...
http://www.newegg.com/Product/Product.a ... 6814131481
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
bdub
Postby ROFLCOPTER » Fri Apr 26, 2013 6:38 pm
thanks for reply,yes its with the AMD and im running it off of arma 2 mod.
windows 8
HP pavalon
It seems that certain games run fine while others are insanly low fps from what i have been playing
ROFLCOPTER
Postby Mr T » Fri Apr 26, 2013 11:43 pm
HP Pavilion - ditch the PSU first and foremost that came with the system and up it to a decently branded one, ie Corsair, OCZ, Antec and the ilk and get a minimum of 750w. The gintense graphics of some games can cause the video to stutter because it may lack enough actual power from the PSU and fall over, even with inbuilt and onboard. I will also say something on that CPU you that may or may not work with the core voltage, but you need a decent power supply.
Return to Recommendations
