New photo editing <$2000 build with i7 3770K
Postby philmar » Sun Apr 21, 2013 4:38 pm
This build is for photo editing with Lightroom and Photoshop CS3. I probably will start to use the video capabilities of my Canon 5D3. This is what I have so far.
CPU - Intel Core i7-3770K 3.5GHz Quad-Core
SSD - Samsung 840 Pro Series 240 GB
HD disks - 2 x WD Green (WD30EZRX) 3TB
Case - Antec P280
The power supply, CPU cooler will sort themselves out later. What I really need help with is the mobo, memory and video card.
MOBO: I have decided to go with a 1155 socket and Z77 chipset. I have never overclocked because my hobby is photography not voltages, latency, multipliers ect. I never liked going in to the BIOS and trying to figure out what to do. And then fine tuning voltages, multipliers and monitoring temperatures aaargh!! But I think I'd like to OC this new build because if one can get better performance for free, why not? And more importantly I read now that some ASUS mobos like Sabertooth Z77 and ASUS P8Z77-V DELUXE have automatic OC features on them. If you don’t want to perform those complicated OC you can easily select the performance mode on the BIOS setting for painless overclock. It will result in 4.2GHz frequency with full system stability using the Core i7-3770K. This appeals to me. A LOT. I would pay more for a mobo that allows EASY overclocks. These aren't boards for the casual builder, but satisfy the most driven overclockers and tweakers.
Similarly, I don't want to pay for features I won't use/don't need: WiFi, wireless features, customizable fan controls, multi-GPU support, ECC memory, surround sound, remote-control access via a smartphone or tablet.
So I can easily afford either of the Sabertooth Z77 and ASUS P8Z77-V DELUXE but why overspend? Can anyone suggest another Z77 mobo that has easy OC features but less features like wireless connectivity and dual GPU support that I don't need?
Memory: I want 16 GB of DDR 3 RAM. I am clueless about memory. In light of the fact I'd like a mobo with easy OC features that will permit me to OC an i7 3770K at 4.2 GHz is there any type of memory that will work better? I'd pay no more than $150 for it. Will 4 sticks of 4GB work better than 2 sticks of 8gb?
Video Card: I own a Canon 5D3 that shoots video. I definitely will get in to video some time soon. But I don't know what video card I should get. I most definitely do NOT play video games. So I can skimp here I think. But I DO need 2 monitor support.
I thank you in advance for any help.
philmar
Postby evasive » Mon Apr 22, 2013 3:32 am
MOBO:
http://www.newegg.com/Product/Product.a ... 6813157293
Memory: 2x 8GB sticks, reason being that most if not all boards cannot reach full speed when all the slots are filled.
Return to Recommendations
