It is currently Mon Oct 15, 2018 3:41 am
PostPosted: Wed May 16, 2012 1:14 pm
All,
I am hoping to gather some information for a replacement mobo for one of the ill-faded HP Pavilion Elite m9350f Desktop PCs. This is the model that sported the Pegatron/ASUS M2N78-LA (Viola) mobo which had problems with the chipset getting too hot and causing all sorts of intermittent problems. My wife bought one a few years back and it work up to a couple of months ago. Now I have it and I would like to know if anyone could suggest a comparable mobo that could be substituted for the failing component. Below are listed the specifications of the existing mobo:
Pegatron /ASUS M2N78-LA (HP/Compaq name: Viola-GL8E)
Form factor - Micro-ATX: 24.4 cm (9.6 inches) x 24.4 cm (9.6 inches)
Chipset - NVIDIA GeForce 8200
Front-side bus speed -5200MT/s (5.2 GT/s)
Processor - Phenom with Quad Core (Agena) technology 9850
Socket type: AM2+
TDP: 125 watt
Memory -
Four 240-pin DDR2 DIMM sockets
PC2-6400 (800 MHz)
Non-ECC memory only, unbuffered
Intergrated Video, Audio, and Network (1000-Base-T)
Expansion Slots (Minimum)
One PCI Express x16
Three PCI Express x1
I/O Ports
Back I/O Ports
PS/2 mouse (green)
SPDIF coaxial out
Video Graphics Adapter
IEEE 1394
RJ-45 Network (LAN)
Audio: Center/Subwoofer (yellow orange)
Audio: Rear Speaker Out (black)
Audio: Line In (light blue)
Audio: Line Out (lime)
Audio: Microphone (pink)
Audio: Side Speaker Out (gray)
USB 2.0: 4
DVI
PS/2 keyboard (purple)
Internal Connectors
One 24-pin ATX power connector
One 4-pin ATX power connector
Six SATA connectors
One floppy drive connector
Two 12v fan connectors for CPU fan and PC fan
One 9-pin header for power button, reset button, power LED, and HDD LED
One SPDIF audio output connector
One front line input connector (interrupts line input on back panel, Vista capable, requires matching front audio jack odule)
One 9-pin audio header for headphone-out and microphone-in (yellow, Vista capable, requires matching front audio jack odule)
Six USB 2.0 headers supporting 8 USB ports or devices
One 1394a header
Thanks,
David
