Is this a winning combination?
Postby f76 » Sun Nov 17, 2002 5:02 pm
Going to build a computer and it would be great to get some advice...
Am I doing any better here than MSI KT333 Ultra2?
Am I doing any better here than AGP 4x???
old box witk 300w fan
Asus A7N8X Deluxe/GD
Crucial PC2700 DDR-DIMM 256MB CL2.5 6ns.
Glacialtech pro fan
AMD Athlon XP2100+ 1.733 GHz 266 MHz bus
Abit Siluro Geforce4 Ti4200-8X 128MB
Asus CDrw IDE 40x/12x/48x
f76
Postby gamepyrate » Sun Nov 17, 2002 5:09 pm
looks pretty good, though I believe the ti4200 doesn't get any performance increase out of 8x AGP--8x agp is a gimmick like Parallel ATA-133 as of now. if you feel that computer is fast enough then go on ahead, but might i recommend CL2.0 ram and a different CD-RW, like LiteOn or Plextor persay. are you going to get Serial ATA or Parallel ATA drives
gamepyrate
Postby sirchone » Sun Nov 17, 2002 8:11 pm
Check for a CDR/RW with Mt Rainer support - next version of windows will support this, it will allow direct writing to the drive without a third party software packet writing
sirchone
Return to Recommendations
Users browsing this forum: AhrefsBot [Bot], YandexBot [Bot] and 1 guest
