kt400? kt333? AGP8x?
Postby f76 » Fri Nov 15, 2002 12:28 pm
Hi all!
Im looking into building a new AMD system for a freind. since i got my system:
(kt3ultra2+sound
256mb2700ddr
ASUS Geforce4 ti-4200)
im thinking of basically building the same system again.
I found that they are new mobos out with AGP8x and kt400, plus of course graphic cards with AGP8x.
Is kt400 any good? can anyone recommend a card with sound on and AGP8x?
how big is the difference with ddr3200/ddr2700?
how big is the difference with AGP8x/AGP4x?
Or should i get a kt333 card with AGP8x [/quote]
f76
Postby Temptation » Fri Nov 15, 2002 12:33 pm
can't really say right now, but I'm picking up at kt400 board on monday. I'll let you know what I think of it
Woe to the cook whose sauce has no sting!
http://service.madonion.com/compare?2k1=5128745
Athlon XP 1600+ (not overclocked yet)
512mb DDR400
Soyo Dragon KT400 Ultra Platinum Edition
MSI Ti4600
SB Live! Platinum 5.1 w/ Live! Drive
WinXP Pro
Temptation
Postby Johnny Mnemonic » Fri Nov 15, 2002 2:24 pm
The improvement of KT400 over previous boards is slim, but may be worth while if you are looking for a new motherboard with 8x support. However I would also consider the nforce2 motherboards. If you don't see a clear choice in what board is for you, then it would probably be best to wait for the KT400a chips to arive. Either way the KT400 or nforce2 boards will support 333fsb AMD chips.
0100101001001101
Johnny Mnemonic
Postby IanZ28 » Fri Nov 15, 2002 7:33 pm
At this time there is no performance increase with either the AGP 8x or the 400mhz ram.
AMD has only recently released their 166mhz fsb processors......this equals the pc2700 ram.
I'm hoping (gambling) that the future increases in performance cards, CPU's, and ram will allow me to upgrade on my new board, as I only build a new PC every few years and upgrade whenever prices are resonable.
IanZ28
Postby IanZ28 » Fri Nov 15, 2002 7:38 pm
I'm hoping (gambling) that the future increases in performance cards, CPU's, and ram will allow me to upgrade on my new board, as I only build a new PC every few years and upgrade whenever prices are reasonable.
IanZ28
Postby sirchone » Sun Nov 17, 2002 8:19 pm
Ill second the nforce2 suggestion, should give a more stable solution and the sound on it will be great.
sirchone
Return to Recommendations
Users browsing this forum: Lindex [Bot] and 3 guests
