what board to get??
what board to get??
Postby uniquemale69 » Thu Nov 14, 2002 10:46 pm
I am planning on getting a AMD Athlon XP 2400+ 266 FSB - 2.0 GHz
What board do yall suggest that I get for stableness and the ability to do some OC'n. I would like to try to stay under $120 if at all possible. also should I get water cooling for it or is there a HS/fan that will suffice.
I do alot of multi tasking and some quazi hard core gameing mostly I am looking for a board that is user friendly and stable with the ability to be upgraded in the future.
Help humanity .....join the
Motherboards.org
folding team! 33258
uniquemale69
Re: what board to get??
Postby Southwind25 » Fri Nov 15, 2002 5:53 am
uniquemale69 wrote:I am planning on getting a AMD Athlon XP 2400+ 266 FSB - 2.0 GHz
You might look at the Asus A7V8X. Newegg has a refurbished board for $89 with free shipping. You can see it at:
http://www.newegg.com/app/ViewProduct.a ... 14&order=1
or they have a new board for $119(free shipping) at:
You can access 12 reviews of it at: http://www.8dimensional.com/mainboard-r ... 400reviews
Southwind25
Postby sirchone » Sun Nov 17, 2002 8:41 pm
If you wait a little while or add about 25 dollars to your budget get the Asus A7N8X nforce board at new egg ( also check out the leadtek nforce2 board)
sirchone
Postby jsheinz » Sun Nov 17, 2002 9:34 pm
The MSI KT3 Ultra's are a great line for that processor. I have one and Love it!
jsheinz
Return to Recommendations
