A boot manager for Linux and WinXP
Postby gamepyrate » Fri Oct 11, 2002 4:49 pm
I need a boot manager that can run in DOS/win9x/xp that supports Linux partitions. I had used XOSL, but since I replaced my video card I can't use it any more. Thank you.
gamepyrate
Postby Hardware Junkie » Sat Oct 12, 2002 12:59 am
LILO
Postby EvLwMn » Sun Oct 13, 2002 9:22 am
Yes, I second HJ's recommendation. I use LILO myself and have found it to be the easiest to use and configure.
EvLwMn
Return to Operating Systems
