It is currently Fri Sep 21, 2018 12:14 pm
PostPosted: Fri Oct 11, 2002 7:51 am
Just built a new system, POST with no problems. Try to run a new install of XP Pro and when I get to the license agreement it ask for "F8 to accept" I hit F8 and nothing happens. It is just locked up on the license agreement screen. What is the fix? Everything up to this point was going well.
MOBO: MSI KT4 Ultra with Athlon XP 2000+ and 512MB Corsair XMS Ram
HDD: WD 80GB Special Edition (configured as single master)
I checked the BIOS Setup and everything seems to be as it should be.
I am using an OEM version of Windows XP Pro. Called Microsoft and received no help there unless I was willing to give them some dead presidents. Would just as soon not do that if I can avoid it.
This has always been a good forum for information and problem resolution. Hope someone can help on this.
Thanks
PostPosted: Fri Oct 11, 2002 8:19 am
Check all your cabling and jumpers (yet again?), try the RAM in a different slot, clean your CD with XP on it, clean the CD-ROM and don't install from a DVD player 'cos this can cause this.
PostPosted: Fri Oct 11, 2002 8:48 am
Did all that. Moved RAM to another slot, checked all jumpers and cables and checked the WinXP disk. Still hangs up at the licensing screen. I can scroll up and down the licensing page but it will not accept F8.
Bad disk maybe?
"Your life is the sum total of the choices you've made. If you don't like your life, make better choices."
PostPosted: Fri Oct 11, 2002 10:09 am
Could be a bad keyboard?
PostPosted: Fri Oct 11, 2002 12:28 pm
The keyboard works. I can page up/down and exit setup just not continue on with F8. I have used the keyboard in the BIOS Setup and it works fine.
I am installing an OEM version of WinXp. Will the OEM version still format and partition the HD?
PostPosted: Fri Oct 11, 2002 12:30 pm
What kind of keyboard? USB? PS/2? Once you hit F8, can you do nothing else afterwards? Can you still page up and page down (as if you really didn't hit anything) ?
PostPosted: Fri Oct 11, 2002 12:52 pm
A new Logitech Keyboard, USB with a PS2 adapter. Hitting F8 has no effect what so ever. I can still page up/down and exit. The keyboard works fine navigating around the BIOS setup. Very strange!
PostPosted: Sun Oct 13, 2002 6:53 pm
It did that to me with my new system and I opened and closed the rom drive and weeeeeeee it finally finished.
PostPosted: Sun Oct 13, 2002 7:23 pm
Try straight USB. The only thing I can think of is that the keyboard driver(s) used in the XP installer do not work with that keyboard.
PostPosted: Sun Oct 13, 2002 7:42 pm
Thanks
In the BIOS, is PNP OS set to Yes? Sometimes this fixes problems like this... I've fixed a lot of Windows setup problems with that one alteration. I once had two identical systems that I was installing Win98SE on, and one would hang at a certain point every time; the other installed flawlessly. The only difference was PNP OS setting in BIOS... changed it, and woila...
-Jem
