Error when starting 98se
Postby ink » Sun Oct 06, 2002 5:25 am
PB 680 somthing, p-166, edo 64 meg, bios v.1.00.06,
I am having trouble running 98se. It installed ok but just before it completes I get the option to start in safe mode.etc...etc... I have been getting errors like:
HIMEM is testing extended memory
Windows XMS driver version 3.95
extended memory specification (XMS) version 3.0
Copyright 1988-1995 microsoft Corp
HIMEM.SYS has detected unreliable XMS memory at address 01040fe2
XMS driver not installed
HIMEM.SYS missing
error loading GDI.exe
I can't seem to get the 98 boot disk working either, I/O error.
I think the bios needs to be updated, I tried no luck and have posted that ques in the "BIOS" forum.
Can any one link a 95 boot disk here?
Thanks
Help humanity join Motherboards.org Folding
IBM X440 IBM Netfinity x 2
Abit NF7S replaced by DFI Lan Party
2600+Mobile@2540
2x1Ghz OCZ
MSI RX9800pro R360
Aardvark ProQ10
Skyhawk Aluminum
ink
Postby len444 » Mon Oct 07, 2002 8:24 pm
if the floppy drive light stays on, then flip the data cable over
some stuff that i found relating to some of your problems- seems like wiping the disk clean and starting over would be one approach- your on board cache might be bad-some instructions on diagnosing/ bypassing as well. seems like you've got some extra work ahead- was this a dumpster recovery/ dive prize?
http://support.microsoft.com/default.as ... US;q109845
http://support.microsoft.com/default.as ... 4&LN=EN-US
http://www3.sympatico.ca/rhwatson/dos7/v-himem-sys.html
len444
Postby ink » Tue Oct 08, 2002 3:10 am
Bottom of the closet find, cpu from a friend, memory from trade.
Thanks for the info, I got the bios set nice(latest ver. flashed OK. Got problems with ie now. It may come together, I'll just have to keep 95 for now... I've loaded the 28 discs so many times, I've forgoten how fun that was.
2600+Mobile@2540
2x1Ghz OCZ
MSI RX9800pro R360
Aardvark ProQ10
Skyhawk Aluminum
ink
Postby len444 » Tue Oct 08, 2002 7:13 am
28 disks- ouch! 8O
win 95 boot disk here:
http://www.bootdisk.com/original.htm
i'd use the win98 boot disk, and delete the partition(s), create new ones, and format w/ fat32 (enable large dr support). then use the win98 cd and disk 1 of win95 (qualifying version of previous windows os), and w/ the product key #'s at hand, load up win98 (will do a full install instead). probably in your best interest to tweak win98 by modifying/ stripping out the unnecessary stuff (something about removing outlook, and outlook express, and if i'm not mistaken IE, and replacing w/ other faster more stable components).
possible that you'll have to replace some cache- if you disable cache as link recommends, and relevant error message disappears- a local computer recycler might be able to help out.
len444
Postby ink » Wed Oct 09, 2002 4:06 am
Thanks all
I got 98 running, not 98se. It was a mess. scan disk had nothing to report yet during install I had to skip many a file that wasn't found and crash after crash.
I'm giving up for now on this one. I've got an old IBM board in the garage, under some debris...maybe that will work???
I also got my Epox 8k3a+ back and it is still crashing.
Thanks again all.
2600+Mobile@2540
2x1Ghz OCZ
MSI RX9800pro R360
Aardvark ProQ10
Skyhawk Aluminum
ink
Return to Operating Systems
