It is currently Wed Sep 19, 2018 11:25 pm
PostPosted: Sat Oct 05, 2002 7:50 am
I have a problem I have not encountered before....PANIC!
I have installed Win98SE on to a new hdd on a Soltek mobo with a Athlon 650mhz. 384MB RAM. 40gb hdd.
Installed from directory on hdd. Copied the Win98 folder off the Windows CD to the folder on the hdd and installed from there, as I have done a thousand times before.
At the end of the install, when it reboots after setting up the Control Panel, etc. it gives an error message:
"Windows encountered an error accessing the system registery. Windows will restart and fix the registery"
Which it does and all seems okay, untill I try to install something else and it happens again and the app I have just installed is not installed because windows has taken it back to a registery before the install.
I have reformated the hdd a couple of times and the same thing always happens.
Any ideas...please :?
PostPosted: Sat Oct 05, 2002 8:39 am
Windows 98 will only reinstall to the same location on computer. You need to remove the HD with WIN98SE on it and then install the OS off the CD.
PostPosted: Sat Oct 05, 2002 9:00 am
No, you're wrong there. I've always installed from the hdd.
Format your hdd, from the C: prompt make directory Win98, copy all files from Windows cd folder Win98 to the new WIN98 folder on the C: drive.
Run Setup from C:\Win98\setup.exe
I think it's the best way.
PostPosted: Sat Oct 05, 2002 9:10 am
I think I have found the problem...I think....
There were three memory modules in there: 2 x 126mb 133mhz and one rogue 64mb module with no discernable markings.....
I've whipped out the rogue module and all seems okay.... I hope...
I love these folk who tinker... ask them what they have done before it all went wrong and the answers always the same.... "Nothing!"
:roll:
PostPosted: Sat Oct 05, 2002 11:31 am
Of course. Its everyone elses problem that the system is broken.
Btw, just to speed up future installs....just do SETUP /IS /IW
PostPosted: Sat Oct 05, 2002 1:52 pm
/IS = no scandisk but what is /IW ?
PostPosted: Sat Oct 05, 2002 2:03 pm
Bypasses Microsoft EULA (End User License Agreement) licensing screens/dialog boxes.
There are a whole slew of them that would speed things up
/IM
Skips the memory check.
/ID
Skips the disk-space check.
/IS
Doesn't run ScanDisk.
/IQ
Skips the check for cross-linked files.
/IN
Runs Setup without the Network Setup module. Note: The /a and /n options are no longer valid. Use NETSETUP.EXE instead.
/ie
Bypasses the Startup Disk Wizard. The %windir%\Command\EBD folder and the Emergency Boot Disk are not created.
/ih
Skips the registry check.
/iv
Skips the display of billboards during an upgrade Setup within Windows.
PostPosted: Sat Oct 05, 2002 7:00 pm
Ok, I'm curious now. Why would you want to install from your hard drive? Slow CD-Rom?
PostPosted: Sat Oct 05, 2002 11:17 pm
Well, the reason I do it is because it saves all those "Please insert Windows 98 disc" each time I need to add anything or check anything. The path to the install is always back to the win98 folder on the hdd.
(also, and don't tell anyone.... I use the same disc for all my machines in diiferent rooms and the cd is always in the wrong room :roll: )
PostPosted: Mon Oct 07, 2002 5:00 am
Ok, that's a pretty good idea. If I had more than two computers in more than one room I would probably do that from now on...
