annoying pop up in XP
Postby icdengineer » Thu Oct 03, 2002 10:26 am
Every time I log in to XP I get this annoying pop up screen that says
"You or a Program you are using is requesting an internet connection...blah blah"
There is a box to check saying don't ask me again until I log on next time..
Is there anyway to get rid of this signal? what is it anyway?
" Your mother was a hamster and your father smells of elderberry"
icdengineer
Postby Hardware Junkie » Thu Oct 03, 2002 11:34 am
Well "a Program you are using is requesting an internet connection" :P
The message box is giving you the answer to your question. Something like Kazza, AIM/MSN/ICQ/Etc.., Seti (and the list goes on) is starting up when you first login.
You should go through each program you have in your task bar and see what might be doing it.
You can also goto MSCONFIG and click on the startup tab and disable anything running in the background that is not needed.
Check here for a list of possible programs:
http://www.pacs-portal.co.uk/startup_pa ... p_full.htm
Postby icdengineer » Thu Oct 03, 2002 11:42 am
ahhh....my son the little rascal has AIM....god I hate that thing...so that must be doing it...there also is that stupid MSN messenger icon at the bottom of the bar...is there any way I can change it so that they only startup on request?
icdengineer
Postby Hardware Junkie » Thu Oct 03, 2002 11:58 am
Yep you'll have to examine the options available in the individual programs and there are entries in MSCONFIG for them aswell...
Postby icdengineer » Thu Oct 03, 2002 12:00 pm
Okay, this may sound incredibly stupid, but i have only had XP running for about a week...how do I open MSConfig? thanks
icdengineer
Postby datektrader21 » Thu Oct 03, 2002 12:03 pm
click start then click on run then type msconfig and hit enter
datektrader21
Return to Operating Systems
