win98 SE doesn't reboot in Ms-dos mode/ i flashed my bios
Postby adamis » Thu Sep 12, 2002 11:11 am
win98 SE doesn't reboot in Ms-dos mode/ i flashed my bios before this
is a bios problem???
please tell me possible causes...
thanx!!!
adamis
Postby len444 » Thu Sep 12, 2002 11:31 am
are you within windows, when you try to reboot in the msdos window (dos, and msdos are different- msdos is an 'emulation' of dos w/in windows, dos is entered while booting up.
hope that you didn't flash your bios within the msdos emulation window- needs to be performed in dos. trying to flash w/ in msdos is supposed to be dangerous, as it can screw up your hard drive.
try to reset the cmos jumper/ or remove battery- probably 30sec- 60 sec., then retry booting up the pc
len444
Postby adamis » Thu Sep 12, 2002 12:16 pm
Hi,
no no... i mean... i flashed the bios with a boot disk from DOS...
ad everything's ok!!!
but my problem is that windows doesn't reboot in MS-DOS mode
when i use the
STARTmenu>shut down the sistem... >" Suspend" "reboot" - "shutdown" - "reboot in MS-DOS mode"....
reboot in msdos doesn't work
is it a BIOS problem?
my options are in Spanish... i don't know how is exactly in english....
thanx!
adamis
Postby Hardware Junkie » Thu Sep 12, 2002 1:27 pm
What happens now if you actually try to reboot in MS-DOS mode? Does it freeze? Shutdown?
Postby len444 » Thu Sep 12, 2002 2:13 pm
i thought it was shut down in ms dos mode- i'm in win2k right now, i'll have to reboot in win98 to check it out- later though. might want to run system file checker- start>run>(type in)SFC<enter> run program- replace missing/corrupted items from the win98cd (extracts from). might help.
len444
Postby len444 » Thu Sep 12, 2002 2:23 pm
i am wrong- restart in ms-dos mode it is. i've got win98se as well. going to try it to check it out.
basically leaves windows, and goes into dos- where you can work in dos- i have to physically reboot the machine (switch, ctrl+alt+del, ect...), or shut the sytem off while in dos- it's never 'rebooted' on it's own w/ that option.
len444
Postby useless comment » Thu Sep 12, 2002 2:39 pm
adamis, do you have an 'Exit To Dos' shortcut in your Windows folder? If you do, have you made any changes to it?
Windows normally makes sure that it's created if it doesn't exist, unless there is a problem. Otherwise, it may not work properly if the settings have been altered in a bad way.
It's already been asked but what exactly happens when you choose 'Restart in Dos Mode'? Does it just restart windows normally? Crash? Freeze? Play dead? Roll over? Pee on itself?
useless comment
finally solutioned!!!! (sorry bout my english!!!)
Postby adamis » Thu Sep 12, 2002 8:31 pm
i cleared my CMOS, load default bios, restart...
try exit windows with reboot in msdos mode,....
and i works ok!
just have to clear CMOS y reconfigurate setup...
thanx for ALL guys!!!
adamis
Return to Operating Systems
