What do you think about the compress old files in XP??
Is it worth compressing your old files?
Yes
3
30%
No
3
30%
Or, do you just not care
4
40%
Total votes : 10
Postby jmstacey » Wed Sep 11, 2002 9:11 pm
WindowsXP has a feature to compress your old files after a certain time has gone by that they have not been accesed. Is there a risk to compressing files anymore? Is it worth compressing your files just to free up more space? How much will it slow down your system, say you haven't played a game in a long time so it is commpressed. How long is it going to take to uncompress in order to be used?
-Jon-
jmstacey
Postby useless comment » Wed Sep 11, 2002 10:38 pm
This sounds like it could be useful in certain situations, such as if a person uses their machine in a business setting and they have alot of old invoices that pile up. If you just use your comp for gaming and net surfing then don't bother with it - rar or zip your stuff on your own time when you think it is necessary.
useless comment
Postby Phillipste » Thu Sep 12, 2002 6:20 am
I used it on my laptop under Windows 2000. It worked great and freed up close to 100 MB. Opening a compressed file did not take a significiant amount of time.
I had lots of spreadsheet and word documents. Many were not used that often but the day I deleted it or removed it was the day I would need it. Since I pride myself on always being prepared I though it was worth it.
The only problem was the first time I did it, it took close to an hour. After that the time were resonable.
On my desk top I occasionally look at the number that DiskCleanup reports. It never shows significiant savings and I have never done it on a desktop. Also for desktops I keep all those files on CD-ROMs.
ANTEC SX1040b case,ASUS A7V333,AMD Athlon XP 2200+ ,Thermaltake Volcano 9
512mb Corsair PC2100,120 GB WD w 8mb Cache,GAIDWARD Geforce4 TI4600,NEC Multisynch A500
Phillipste
Postby jmstacey » Thu Sep 12, 2002 4:50 pm
The estimate for mine was 1.7 GB. Just wondering the best corse of action.
-Jon-
jmstacey
Return to Operating Systems
