Screensaver won't turn on
Postby andrey » Mon Sep 09, 2002 6:58 pm
Running windows XP, Samsung 955DF monitor with latest monitor drivers. Gainward Geforce Ti200 video card.
I have been doing alot of tweaking, setting changes, and stuff like that, but I just can't figure this one out.
going to display properties, I turn on the screensaver, set it to one minute and turn on passowrd protect. 5 minutes go by, no screensaver. same thing really with the "turn monitor off after X minutes", it just won't do it.
any help with this?
________
WEED BUBBLERS
andrey
Postby Wyrm73 » Mon Sep 09, 2002 8:55 pm
Check your BIOS settings. You may have the power management settings disabled. Also check under the power options icon in the control panel.
Wyrm73
Postby andrey » Mon Sep 09, 2002 10:37 pm
everything seems fine..
what causes a screensaver to come on? lack of mouse/keyboard movement? or lack of CPU/HD activity?
screensaver still isn't coming on..
________
WIKI VAPORIZER
andrey
Postby d-con » Tue Sep 10, 2002 3:07 am
Lack of mouse/kbd movement.
d-con
Return to Operating Systems
