Windows XP OS with Windows 98 exterior
Postby pgiustino » Fri Sep 06, 2002 2:39 pm
If I bought the XP version of Windows, could I download a program to make it run with a 98 layout? I've tried using the XP, but it seems so strange compared to my familiarized 98 system. Navigating to me is much easier in the 98 format. Just wondering. Thanks.
MSI K8t Neo Fis2r
pgiustino
Postby GillianTan » Fri Sep 06, 2002 2:48 pm
You can right click on your start button in XP, go to properties, and set the layout there to look like 98. Then you can right click on My Computer, go to properties, click advanced tab, then performance. Turn everything off, that w/ill give you the regular start button.
My NEW 3dMark score http://service.madonion.com/compare?2k1=4955820
Chaos reigns within. Reflect, repent, and reboot. Order shall return...
GillianTan
Postby Hardware Junkie » Fri Sep 06, 2002 2:48 pm
Switch Control Panel to Classic View...
Also you can run WIndows XP in performance based mode....which looks exactly like Windows 98,.
Control Panel --> System --> Advanced --> Under Performance click Settings....Click on "Adjust for Best Performance" and click OK...
Should look "normal" now...
Postby pgiustino » Fri Sep 06, 2002 3:57 pm
Alright, thanks alot.
MSI K8t Neo Fis2r
pgiustino
Return to Operating Systems
