amd xp with win98
amd xp with win98
Postby Picturef1.com » Thu Sep 05, 2002 5:00 pm
I am still running win98 but am going to upgrade system to amd 1.8 XP. I wont to keep costs to a minimum so will win98 workproperly or do I need win xp.
thanx
Picturef1.com
Postby jsc1973 » Thu Sep 05, 2002 5:12 pm
Windows 98 works fine with the Athlon XP or any other CPU in its class. Don't be thrown off by the name...the "XP" doesn't mean it won't work with OS'es other than Windows XP.
That being said, I would recommend that you should upgrade to Windows 2000 or XP on an Athlon XP system, for these reasons:
1. The NT kernel of 2000/XP is much, much more stable than Windows 9x.
2. There is no performance penalty for doing so on a fast CPU with adequate memory (128 MB for 2000, 256 for XP).
3. Your applications will run better under 2000 or XP because those versions were written with code optimized for newer CPUs than Windows 98, which was written in 1996-97 on assembler tools optimized for Pentium MMX and K6 processors.
4. More than 256 MB of RAM is pretty useless under Windows 9x. On 2000 or XP, you can go up to the limit of your chipset and it will work.
jsc1973
Postby gamepyrate » Thu Sep 05, 2002 7:31 pm
If you like stability and compatibility, stay 98SE. No problems will arise, and most of the time it performs faster than XP, because well, XP was a horribly written OS. Security flaws all over the place and incompatibilities with some 9x programs and devices.
gamepyrate
Postby Wyrm73 » Thu Sep 05, 2002 9:33 pm
I agree with the compatiblity protion of this statement as I have encountered many issues with older hardware and XP. As for the stbility, XP wins hands down IMO.
Since you said price was an issue, I would stick with 98. It works fine with new hardware- just hang on to the driver disks you get with the motherboard and other hardware, as you will definately need them.
Wyrm73
Postby Johnny Mnemonic » Fri Sep 06, 2002 5:19 am
Heck ya, stick with 98SE. I have an AMD 1600+ XP chip and have no problems. I even run 512MB of DDR, which some say is Unstable with 98SE. I can keep it up for days without rebooting, really, why would I want to do that? I mostly play games with my PC, so WIN98SE does the trick. It's quite stable (just watch what you install onto it), and it gobbles up less system resources than 2000/NT/XP/ME.
0100101001001101
Johnny Mnemonic
Postby len444 » Fri Sep 06, 2002 8:41 am
:!: yes, no problem- buy the cpu now!
:?: will your motherboard support the xp cpu's?
len444
Postby len444 » Fri Sep 06, 2002 1:15 pm
haven't adjusted your vcache settings in system.ini- might be a good idea- i'd follow the instructions as per bootdisk.com (i ran into the insufficient memory bsod w/ 512meg ddr, adjusted vcache- haven't seen it since! it was norton system works- type of intensive program that affects the os?!?):
http://www.bootdisk.com
btw, i've found that win2kpro is almost twice as fast when using dsl, and can have more pages open at the same time (as compared to win98se)
len444
Postby Zero » Mon Sep 09, 2002 11:11 pm
go with xp 98 is only for system that dont have power to run like 700mhz system ifu bought a amd xp put that 1.8ghz performance to use get xp pro is better than home
ya i know i suck at typing
Zero
Postby datektrader21 » Tue Sep 10, 2002 12:31 am
whats a amd 1.8 xp?
windows Xp Rocks
datektrader21
Postby Zero » Tue Sep 10, 2002 10:40 pm
amd xp 1.8 is 1.8ghz o r xp 1800 something like that
Zero
Return to Operating Systems
