NON Paged fault Paging area BLAH BLAH
Postby paputzback » Thu Sep 05, 2002 5:59 am
I have tried all my sticks of ram and get the same error w/different hex codes.
So I don't think it is physically the memory.
I have an ECS k7VZA rev 3. board
1ghz AMD, ATI 7500, currently the onboard sound is disable and I don't have a sound card installed while trouble shooting.
I have and adaptec 1200 card with a maxtor 30 and a maxtor 40 gig in a striped array. A 13 gig maxtor on ide 0 a 40 gig western digital (the only 5400 rpm drive) on ide 1. Each secondary channel has a DVD or cdrw on it.
I get the error when ever I try to copy a large amount of data from drive to drive. Any combination. That is the only time it crashes.
I've disconnected the CDrom and DVD and still get the error.
I am using the default drivers for all the devices that XP installs.
If it might be the board can someone recommend a good board with Raid and that will use the sdram.
I am in the process of building a new SFF system but I want to use all the above mention parts other than the raid card to have a stable file server.
But If it is going to be doing a lot or reading and writing to hard drives I can't have it crashing al lthe time.
Postby gamepyrate » Thu Sep 05, 2002 2:55 pm
Have you updated your VIA drivers? and it happens when copying from any of the drives?
Installed the VIA 4 in 1 drivers
Postby paputzback » Fri Sep 06, 2002 5:06 am
Now the error has gone from Non_paged.... to Bad Pool Caller.
Any Ideas.
Are there any programs that test RAM?
Postby donniebrasco » Mon Sep 09, 2002 12:51 pm
I had a similar problem once.
I resolved it by disabling the dram 'burst' setting on my motherboard through bios.
Hope this helps. :idea:
"How can I compare thee to a summer's day...?" (ode to motherboard)
Asus A7V333 m'board
Gainward GeForce 4 MX440
256Mb PC2700 Crucial RAM
WD Caviar SE 80Gb & Fujitsu 10Gb HD
Samsung DVD-ROM
Netgear NIC
Return to Operating Systems
