For all you networkers!
Postby len444 » Thu Sep 12, 2002 6:32 am
suppose sometimes it's whatever works. wonder why the SB card would need irq 11, wheras the CM card would take irq 5- would this be configured by the card manufacturer?
seems that the CM card picked the correct IRQ:
http://www.webopedia.com/quick_ref/IRQnumbers.asp
i just remembered something that might work- in bios disable plug and play os, which then lets the bios handle IRQ (unless irq's are signal related to the specific cards?)- might/ might not have worked (for adding a card to the system- not changing irq while leaving a card alone).
len444
Postby Mr T » Thu Sep 12, 2002 10:03 am
The reason why I realised it was the MAC address was the fact after each LAN card appered a # and a number, refering to a network ie network 1,2 and so on, and I couldn't get back to number 1. There were no IRQ conflicts, everything seemed fine that end (one of the first things I thought of).Anyway thanks for all the input I'm off to play with my new RADEON 9700pro :D
Postby ether.real » Mon Sep 16, 2002 4:15 am
That is kinda odd because i got 2 NIC I swap between, using same IP. I have the setup as LAN1 and LAN2 and I disable whatever I am not using. I also found that after setting shares and rebooting, it would not stick unless I disabled Norton AnitVirus, rebooted, verified the share stuck, re-enabled NAV, then rebooted again.....
ether.real
Postby feto » Tue Sep 17, 2002 5:13 pm
hey mr. t
how's that new radeon workin???
is it worth the money?
feto
Postby Mr T » Tue Sep 17, 2002 9:38 pm
That RADEON...................OOOOOOH, baby, works like a dream. I would wait though until prices start dropping (ie when nVidia release Geforce 5).
Postby feto » Wed Sep 18, 2002 12:12 pm
whoo......its gonna be a while for nvidia to release gforce 5
but i'll wait...
readeon 9700 is most probably gonna be my next buy
feto
Previous
Return to Operating Systems
