It is currently Tue Sep 25, 2018 1:37 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2, 3  Next
 Post subject: For all you networkers!
PostPosted: Tue Sep 03, 2002 1:30 pm
Why can't I see any shared drives over my LAN, when I can have internet sharing? All IP addresses are static apart from the ISP connection and sharing is enabled. The OS is winXP pro on all systems and I have tried everything I know!
PostPosted: Tue Sep 03, 2002 3:54 pm
Same workgroup name on all PC's? Have you tried calling each PC by computer name? "//COMPUTERNAME" in a command prompt should bring up a list of all drives on that computer. You can also try each PC's. IP address directly. Make sure all network settings are the same on each PC. (TCP/IP installed, Client for Microsoft Networks, Primarly logon is the same, etc)
PostPosted: Tue Sep 03, 2002 4:07 pm
Same things I would check as well Johnny. Sharing internet and file sharing are not related. One can happen when the other will not.
My NEW 3dMark score http://service.madonion.com/compare?2k1=4955820
Chaos reigns within. Reflect, repent, and reboot. Order shall return...
PostPosted: Tue Sep 03, 2002 9:31 pm
They are all under the same workgroup, I can even ping them in the command propmt!
PostPosted: Tue Sep 03, 2002 10:02 pm
Have you gone through and set sharing permissions on each drive to be shared or just enabled file sharing? There is a check box to share files over a network under the sharing tab when you go into the properties of each drive .
PostPosted: Wed Sep 04, 2002 1:56 am
Dont do any of the stupid wizards. If it asks you to use a wizard to configure it, click no and do it manually.
PostPosted: Wed Sep 04, 2002 7:41 am
Done all that and done it manually 'cis I know the wizards are crap!
PostPosted: Wed Sep 04, 2002 12:01 pm
Unfourtuntely this is the point for me where I actually have to see what you are seeing or be there.... :cry:
PostPosted: Wed Sep 04, 2002 7:12 pm
Can you at least see all of the computers on the network from each station? Also do you see the hand under each drive icon indicating a shared drive on each computer when you view the drive under My Computer?
PostPosted: Thu Sep 05, 2002 12:19 pm
No computers seen, all sharing protocols set, all modem share, removed and reinstalled TCP/IP, still no joy!
