Activation for XP Pro vs XP
Postby rg560 » Sun Oct 06, 2002 7:45 pm
Im not speaking of devils own version, which by the way, if you do a little research you will see it had the corp files added.
If you can deny that "corp files" exist then I will take your word for it.
Im not looking for a argument, just posting what I know to be true.
rg560
Postby Hardware Junkie » Sun Oct 06, 2002 7:59 pm
Well instead of just throwing crap back and forth saying "You are wrong...no you are wrong...etc..etc.." I preffer to settle it and find out.
I know my Pro copy works with a Corp key and never asked me to register...
Postby GillianTan » Sun Oct 06, 2002 10:30 pm
Me too....copy of Pro works with Corp key
My NEW 3dMark score http://service.madonion.com/compare?2k1=4955820
Chaos reigns within. Reflect, repent, and reboot. Order shall return...
GillianTan
Registering XP
Postby James Fulkerson Jr » Mon Oct 07, 2002 7:59 pm
I just got this computer less than a year ago, and I have had to reinstall the os now 4 times. This time it says that the number has been maxed out. What the hell is with that?
:evil:
James Fulkerson Jr
Postby jmstacey » Mon Oct 07, 2002 8:03 pm
I think you've reinstalled it to many times. THe OS probably thinks its been installed on four computers or something now. You will probably have to either replace the Wpa.dbl file (that is if you backed that up) or call Microsoft and get a special key that works around it.
-Jon-
jmstacey
Postby Hardware Junkie » Mon Oct 07, 2002 8:03 pm
You have exceeded the amount of times you are allowed to reinstall XP, contact Microsoft for an activation code. Might take 5 minutes...
Activation of XP
Postby James Fulkerson Jr » Mon Oct 07, 2002 8:07 pm
Thanks you guys are awesome. If ever there is anything that you need let me know.
James Fulkerson Jr
Previous
Return to Operating Systems
