Activation for XP Pro vs XP
Postby GillianTan » Sat Oct 05, 2002 1:14 pm
Finally! Someone on my side! Thanks Hardware Junkie!
My NEW 3dMark score http://service.madonion.com/compare?2k1=4955820
Chaos reigns within. Reflect, repent, and reboot. Order shall return...
GillianTan
Postby Hardware Junkie » Sat Oct 05, 2002 2:13 pm
I am with you on this one... :wink:
Postby rg560 » Sun Oct 06, 2002 8:28 am
If that were true, then a Corp key would make Pro install as Corp. Doesn't work that way. There are a dozen or so files that are different between Corp & Pro.
There are some files that differ, and they all are related to the WPA.
But all the functional files, are the same.
Try registering a Pro version with a Corp key, it wont work.
The Cd's are different.
rg560
Postby jackdav » Sun Oct 06, 2002 10:23 am
So what happened to the person who had the copies of XP corp? Still got 'em? Lets deal!
________
vapir one
jackdav
Postby GillianTan » Sun Oct 06, 2002 4:58 pm
rg560 wrote:If that were true, then a Corp key would make Pro install as Corp. Doesn't work that way. There are a dozen or so files that are different between Corp & Pro.
Done it. Works fine.
GillianTan
Postby Hardware Junkie » Sun Oct 06, 2002 5:03 pm
Did it, Doing it, Works fine.
Postby rg560 » Sun Oct 06, 2002 5:24 pm
For those who are interested: the files that differ are as follows:
I386\WIN9XUPG
I386\DPCDLL.DL_
I386\EULA.TXT
I386\NT5INF.CA_
I386\OEMBIOS.BI_
I386\OEMBIOS.CA_
I386\OEMBIOS.DA_
I386\OEMBIOS.SI_
I386\PIDGEN.DLL
I386\SETUPP.INI
I386\SETUPREG.HIV
I386\WIN9XUPG\WIN95UPG.INF
rg560
Postby Hardware Junkie » Sun Oct 06, 2002 5:48 pm
Alright just to lay this to rest I am going to find a copy of the Devils0wn on the net and compare it to my Pro Disk.
I am running XP Pro with a Corp key. Have been for months.
Postby GillianTan » Sun Oct 06, 2002 6:30 pm
I actually purchased XP Pro and put in a corporate key. I also downloaded the Devilsown copy and used a corp key, works fine. I dont know who you are getting your info from, but they are wrong.
GillianTan
Postby Hardware Junkie » Sun Oct 06, 2002 6:44 pm
GillianTan: Do you still have the ISO for Devils0wn? Could you upload it to my FTP. I wanna check that out.
mobokive.dyndns.org
username and password: upload
PreviousNext
Return to Operating Systems
