Windows 98 safe mode menu won't go away
Postby gszczyrb » Fri Aug 30, 2002 4:42 am
My system crashed and I had to fix some things using the safe mode. All is better now, but when I start up, I still get that menu that asks how I would like to start 1: Normal, 2: Whatever, 3: Safe Mode, etc.... When I choose normal it works just fine, but I'd tired of havinbg to choose it everytime I boot up.
Is there a way to skip this screen
Thanks,
Greg
gszczyrb
Postby smartz » Fri Aug 30, 2002 6:43 am
Go to start, run and type msconfig. Check under the advanced button and make sure that the option to enable start-up menu is not checked. If that is not checked, have you tried going into safe mode again and then restarting. One or the other should clear your start-up menu.
Smartz
smartz
Return to Operating Systems
