It is currently Mon Jan 27, 2020 10:03 am
PostPosted: Mon Jun 03, 2019 5:51 am
I bought a display desktop PC from Best Buy that has Windows 10 installed
I am curious, in the event that I need to reinstall Windows 10, how would I go about doing that if they did not provide me with an installation CD and the key code
Antec 900 - 650W ATX
Intel DQ35JOE
MS Windows 10-64bit
PostPosted: Mon Jun 03, 2019 6:56 am
I don't think you can - you need that activation code. Typically it's found somewhere on the case on a sticker, but...if it was a display, they most likely removed it (for obvious reasons).
-R
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Tue Jun 04, 2019 7:36 am
even if they removed it, it should come with the system in another form. in this case, go back to Best Buy and ask for the keycode
PostPosted: Mon Jun 10, 2019 8:35 pm
If it is an OEM Windows 10 install, you don'y need a key code. Download the latest Windows 10 using their tool and install it to a minimum 8Gb pen drive. To reinstall, boot from that and install. Once installed windows will activate based on the hardware signature. I have lost count the amount of times I have had to do this when updating windows on the cheaper laptops and small PC's that have a 32Gb SSD (far too small for windows 10, 256Gb minimum to allow for major updates).
