It is currently Fri Feb 28, 2020 5:10 pm
PostPosted: Thu May 09, 2019 6:26 pm
Which tool is recommended for making Windows 10 install disk?
PostPosted: Tue May 14, 2019 10:36 am
Before starting the download get at least some idea of how much of the hardware is compatible with windows 10. It would be not nice at all to start installing and stopping dead in your tracks because the storage controller or network card is not working on 10.
PostPosted: Sun May 26, 2019 4:42 pm
rtithe wrote:
Which tool is recommended, Windows USB/DVD Download Tool and Media Creation tool?
I wasted dozens of DVDs trying to make a bootable DVD,maybe i did something wrong.Media creation tool are the best choice.
PostPosted: Mon May 27, 2019 10:21 pm
The hardware specs are quite good (Intel i5 Processor, 8G RAM and 256G SSD)
PostPosted: Sat Jun 08, 2019 8:25 pm
Wow this is exactly what I want to do because the system I want to install on has no CD/DVD drive at all...Thanks to God and X-2-X
PostPosted: Sat Jun 15, 2019 2:54 am
rtithe wrote:
The spec is quite good. i7, 8G RAM with 512 SSD.
p.s Windows Creation Tool failed as it says some kind of error happened after the ISO being downloaded.
Can you give the exact error message, only then we may be able to help you
PostPosted: Sun Jul 07, 2019 5:57 am
Can't you download the Windows 10 OS file off of Microsoft's website free and put it on a USB flash drive. If you have the COA you should be good to go. The PC's hardware needs to be windows 10 compatible. Might have to set the boot order in the bios to boot first off the flash drive.
KEEP AMERICA GREAT
