It is currently Tue Dec 18, 2018 1:37 pm
 Post subject: Fixed
PostPosted: Fri Dec 08, 2017 8:23 am
I just turned on my Windows 10 PC today and found that all my Desktop & Program Icons gone.
The programs and shortcuts still work. But the icon photos are gone. All that you see it the icon text.
I attached a desktop pic so you can see. The taskbar icon has also changed somewhat. The program icons
are now generic. In the screenshot I have two different browsers and paint open.
All other folder icons are gone. All files show as text, jpg, png,text etc.
The only change I have done to my computer was a few days ago when a Windows 10 update caused the Icon arrows to appear.
So I used Ultimate Windows Tweaker 4.2.2 to remove them. They were fine after I made that change. My computer was fine
until now.
______________________________________________________
Fixed with renamed "Shell Icons" to "Shell IconsX" then rebooted.
 Post subject: Re: Fixed
PostPosted: Fri Feb 23, 2018 7:48 am
maybe the icon cache is corrupt:
http://www.thewindowsclub.com/rebuild-i ... windows-10
it looks like there is a newer version of UWT:
http://www.thewindowsclub.com/ultimate- ... windows-10
Worth a try.
