It is currently Wed Jan 16, 2019 12:11 am
PostPosted: Sun Dec 20, 2015 7:43 am
.... And moving on from my previous thread about the dysfunctional windows 10 Start button - resolved eventually.. Another one has cropped up - NO Windows App Store or any other windows Apps.. They just don't work at all.. Many fixes on the internet that just have not worked. It happened on a clean install that went to a business, came back with no app store access - great!!! And now my machine at home is suffering and I refuse to reset it due to loads of people resetting or doing a clean install for the issue to resurface!!! (plus I would have fair amount of software to reinstall)... :(
PostPosted: Wed Feb 10, 2016 10:12 pm
Hello,
Did you get it working? Looks like a fairly widespread problem with Windows 10 http://www.thewindowsclub.com/windows-store-not-opening
PostPosted: Wed Feb 17, 2016 10:42 am
I ended up doing a clean install and reinstalling programs.. Didn't lose much data, but my windows hard drive is now not for any storage at all.. I updated everything, then found firefox stuttering and spluttering, esp when videos were being played...So all sorted by a) Disable Fast Boot - not needed, this is a PC not a tablet B)Disabled Sleep and Hibernation, the bane of all windows I have ever used C)And under Advanced Power settings disabled Link State Power Management under PCI_Express... All is running well now..
PostPosted: Fri Feb 19, 2016 1:12 am
Good to hear it and there is some useful info there I will try to remember if I ever upgrade a PC to windows 10 :)
PostPosted: Sat Mar 26, 2016 10:34 pm
I've got win10 behaving for me just about.
Shut down was not working at all (just pushing me to logon prompt), but disabling fast boot sorted that out and I disabled hibernation too.
I've killed Cortana by stopping searchui.exe from running. I have to admit I do miss having a search function in the start menu though so I might try and do something about that at some point.
Most of my effort went into removing HP security centre, which was brought across from win7 and refused to uninstall. I ended up just deleting files/startup keys manually and using IObit to clean up some of the crap it left behind.
PostPosted: Sun Mar 27, 2016 5:48 am
Best tool for sorting out the "what's not needed" is still the msconfig process from [Start/Run].
Disable from auto-start what is not required, uninstall after, if not wanted.
Active programs and features are in a protected mode.
