It is currently Wed Jan 16, 2019 4:27 am
PostPosted: Fri Sep 25, 2015 9:14 am
On my XP machien, every time I reboot I get a blue screen that basically says
"A process or thread crucial to application has unexpectedly exited or been terminated".............at the bottom of the message it says,
"Technical Information" STOP: 0X000000F4 (0X00000003, 0X8AD1F5C0. 0X8AD1F734. 0X805D22DA)
"Dumping physical memory to disk:
The computer starts back up fine and Windows starts
But then I get a message:
"MUI Unattend Action"
"MUI unattend action has encountered a problem and needs to close. We are sorry for the inconvenience.
And the only option is the close button
I close the error and the system continues to load fine and works fine.
I cleared the event viewer and reboot and the only error in the log is in the System folder and says
"Souce - TCPIP"
TCP/IP has reached the security limit imposed on the number of concurrent TCP connect attempts.
So now I am curious if all of these are related somehow and what I might be able to do to resolve these issues
Antec 900 - 650W ATX
Intel DQ35JOE
MS Windows 10-64bit
PostPosted: Fri Sep 25, 2015 1:37 pm
Replacing the CMOS battery should solve it..... While in there look for bulging or leaking capacitors on the motherboard, video card and power supply...
PostPosted: Mon Sep 28, 2015 1:03 pm
Will it do this if not connected to any network as well? Same error messages? Same eventlog entries?
PostPosted: Mon Sep 28, 2015 3:22 pm
Is this computer the same as in your signature? If so, I note "Microsoft Windows XP Professional Build 2600 - SP2". It should have SP3 installed, fixes a lot of earlier problems.
PostPosted: Tue Sep 29, 2015 12:37 pm
Psibly a windows upgrade can solve the problem, had U installed some comunications device or program recently, it could be the problem a device or program that needs a newer update of XP
-Wrapped Around Your Fingers-
-The Police-
