It is currently Mon Jun 01, 2020 4:36 am
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Aug 19, 2015 3:29 am
What hardware are you trying to install on? The only issues hardware wise with no intsall is on really old stuff where cpu is not powerful enough (700Mhz and below) or with a via based graphics chip.. If you could list ALL the hardware out that you are trying out, I may be able to point you in the right direction.
PostPosted: Wed Aug 19, 2015 7:42 am
MS XP SP3
MSI-7181
AMD 64 3200+ 2.21 GHz
2 GB DDR RAM
NVidia GeForce 7800 GS
Maxtor 200GB HDD x2
ASUS DVD-ROM E616P
Plextor DVD+/-RW PX-712A
Lite-On Slim DVD+/-RW (USB) **Used for LIVE DVD booting**
PostPosted: Wed Aug 19, 2015 11:08 am
Ok, I can see three possible issues... First off is the Via based motherboard, the onboard graphics has a bug with linux and may be confusing the Xorg driver (Basic linux video driver for all video cards) and causing a no boot. There is also an issue with AGP cards, esp if the linux kernel puts in a proprietary driver (non open source, ie nVidia, ATI), so again no boot to desktop.. And disconnect the Plextor drive until all is up and running.. Finally check everything for bad capacitors.. Try and older distro, I have just installed Lubuntu 10.10 on an AMD Geode LX800 which is running great with Chrome and Firefox... The latest nVidia Linux driver wont support any card below the GTX 400 series (borked a lot of my Steam OS systems)...
PostPosted: Wed Aug 19, 2015 11:55 am
Would those "possible" issues cause a distro to boot one time, then not boot the next?
Because the distros I want to check out more all completely booted to desktop at least once. I was able to use the distro for a bit. When I got tired of it, I rebooted my system, etc.
Debian (Cinnamon)
Peppermint
ubuntu 15.04
ubuntu 14.04
openSUSE
Fedora
Mageia 5
Zorin 10 Core
How old of a release should I try for each distro?
Would a fresh ISO download make any difference? How about a new ISO to Image DVD?
PostPosted: Wed Aug 19, 2015 9:56 pm
... No, if you boot to desktop first time round and everything works it should boot again with no issues. Have you installed one to a hard drive yet? Go through the normal 'troubleshoot' of a minimal install, ie one of everything. Linux is pretty good with hardware, unlike windows, so will tolerate bad ram and so forth. And boot using the ASUS drive, not the Lite-on USB... What is the make and wattage of the PSU?
PostPosted: Thu Aug 20, 2015 12:28 am
Mr T wrote:
Have you installed one to a hard drive yet? .....................And boot using the ASUS drive, not the Lite-on USB... What is the make and wattage of the PSU?
No, I'm just trying Live DVD for the distros now. I want to be sure I like the distro enough before I install.
So you think the Lite-On drive may be part of the problem? I believe the PSU is an Antec 800+ watt.
PostPosted: Thu Aug 20, 2015 12:46 pm
All your hardware should work with no issues, as I said I can see 3 possible issues, but should still work.. Have you tried Slitaz?
PostPosted: Fri Aug 21, 2015 10:28 am
:? No,never even heard of it. What is it?
PostPosted: Sat Aug 22, 2015 2:08 am
http://www.slitaz.org
PostPosted: Sat Aug 22, 2015 10:13 am
:? Ok, I think I will stick to these for now.
____________________________________________________________________
Here's where I stand now.
***Debian (Cinnamon), Zorin 10 Core, Peppermint, Mageia 5 all booted to desktop, and I was able to use each one. :)
Fedora & openSUSE also both booted to desktop, and I was able to use each one. :(
I wasn't able to get ubuntu 14.04 to boot.
Although ubuntu 15.04 booted to desktop, I wasn't able to use it. It won't let me past the username login / password screen. :(
I've tried all the suggested live DVD passwords I could find.
What can I do to run it?
*** I posted this reply while running Debian (Cinnamon) live DVD :)
