It is currently Tue Oct 23, 2018 9:15 pm
PostPosted: Wed Dec 10, 2014 9:45 am
I am doing a remote hook up on my friend's computer to see why windows 7 is running slow.
When ever you go to open something the Webshots picture on the desktop disappears. I tried using Windows7 manager ... it cleaned the registry, but locked up when I asked it to use the junk file cleaner.
I asked it to use Malwarebyte I got the security prompt ... but nothing after that. When using the browser it will lock up too. Sometime it will lock up during boot up. Sometimes it takes a while for it to open a program. However I am able to open my computer or the window update and it working as it should. While this is going on. So something is definitely up with the OS ... any ideas?
Main Rig_Intel i7 4770k@3.50
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
WD100000 SATA 7200RPM
Seagate 1TB SATA 7200RPM
Corsair CX750M
Win7 Ultimate x64
Rig2_AMD FX8120
GIGABYTE GA-M68MT-S2 Mobo
4Gb DDR3 1600
ZOTAC GeForce GTX 550TI
Rosewill M650
Win7 64
PostPosted: Wed Dec 10, 2014 10:52 am
do you have the specs of the machine?
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Wed Dec 10, 2014 1:34 pm
looks like a viral infection
a faulty RAM can cause a lot of extrange errors also
-Wrapped Around Your Fingers-
-The Police-
PostPosted: Wed Dec 10, 2014 4:34 pm
Open the Task Manager and check how many applications are active. More than 6, the system is top-heavy with needless programming active in the background! Also check how many processes are listed. Should be less than 50, if you want a properly running setup.
Ensure that if using a third-party antivirus and firewall program, that only one is active. Two active firewall programs can drag performance down greatly.
Also possibly a viral infection. Do a scan in 'safe' mode, when most viral forms are inactive.
PostPosted: Wed Dec 10, 2014 4:52 pm
Seem to recall Webshots had some nasties a while ago. Try removing it and see if it runs any better.
PostPosted: Thu Dec 11, 2014 6:38 am
Indeed, found many references to problems with a search for "Webshots problems".. and that a "Smile" app had malware!
