Windows 10
Re: Windows 10
Postby Rossco4 » Tue Aug 25, 2015 9:17 am
I tried everything I could
windows 8.1 - worked fine
windows 10 - no internet, cant fix itself
windows 8.1 - works fine
not as good as it thinks it is, is it?
Rossco4
Re: Windows 10
Postby Roach412 » Tue Aug 25, 2015 9:53 am
could still be an issue with drivers - this is why I keep at least one ultra-basic USB wifi adapter.
I'm assuming you don't have any other wifi adapters available to try and verify that way? perhaps grab one from your local electronics store and diagnose - if it doesn't help, return.
also, might have missed it - but have you contacted asus directly?
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
Roach412
Re: Windows 10
Postby evasive » Tue Aug 25, 2015 11:30 am
Me think install driver only, not the utility:
http://www.asus.com/support/FAQ/1013128/
Windows 10 is listed for downloads:
http://www.asus.com/Motherboards/P8Z77V ... _Download/
LAN driver:
http://dlcdnet.asus.com/pub/ASUS/lan/Re ... 052015.zip
(both for 32 and 64 bit)
Try that.
Re: Windows 10
Postby Karlsweldt » Thu Aug 27, 2015 5:36 am
Win 10 has yet again undone my video settings as to the theme and screen saver! Third time!!
Maybe a screen saver is not needed with today's LCD displays, but the F@H screensaver is a minimal overhead feature while doing the GPU folding.
And the social media "apps" have returned too!!!!
Won't take many more instances, and I roll back to Win 7. :mb_grumpy::
Re: Windows 10
Postby Karlsweldt » Wed Sep 02, 2015 2:40 pm
Started the Win 10 F@H system this morning, had to reset some preferences.. and the screen saver.
Then got some updates, and Windows decided to install them without asking!! And now those apps I disabled are all active again, including Wifi auto-connect. That is the last straw. Windows 10 goes out this weekend, never to return.
May be great for social media freaks, but I have no need of it. And why should my programs and apps tell advertisers my habits, and then they tell me what THEY think I need?
Assuredly, a lot of IT personnel will be going bald from the Win 10 experience.
The "one for all" Win 10 version is not appropriate.. there should be business, portable and other versions.
Reality is out here, folks.
But that is my personal view.
Re: Windows 10
Postby Mr T » Fri Sep 04, 2015 11:09 am
Karlsweldt wrote:Started the Win 10 F@H system this morning, had to reset some preferences.. and the screen saver.
You need to edit your privacy settings. Google is your friend and there is an app for it too...
Re: Windows 10
Postby Karlsweldt » Fri Sep 04, 2015 3:18 pm
Went through that whole process. Any feature or app not required or wanted was disabled (turned off or removed). Then when Windows got new updates, all was back to original status!
Re: Windows 10
Postby Mr T » Sat Sep 05, 2015 8:13 am
Check out DoNotSpy10... Bear in mind going back to win7 is not a good option as support is ending shortly so no bug fixes or security patches... I would stop with windows 10 or look at alternative route, such as linux or mac...
And WARNING if you don't donate to the app, it uses OpenCandy as part of the installation purpose. If using Malwarebytes it picks it up and you can delete it and carry on installaing DONotSpy. Opencandy is picked up as a PUP (Potentially Unwanted program) and after testing it caused no harm whatsoever to my system. Deleted it using Malwarebytes and ran two scans and nothing else was picked up.
Re: Windows 10
Postby Karlsweldt » Sat Sep 05, 2015 3:04 pm
Win 10 has one last chance to "do it my way or the highway".
Yes, Win 7 active support is done with, but has extended support until Jan. 14, 2020
I do have the AVG suite on all active systems, and they are kept in good health.
My primary system still has Win XP, and as long as AVG and Mozilla accept it, I am a 'happy camper'.
Would have to buy a lot of new programming to replace what is not compatible to any newer OS.
Re: Windows 10
Postby Karlsweldt » Thu Sep 24, 2015 3:31 pm
Win 10 has had its final 'curtain call' with me. Four times in the past month, the system has locked up.
Started the system around 8a EDT today, set the F@H app running. Did not check if still good, until after 4p EDT. FROZEN!!
More than 7 hours of no operation, burning up the wattage.. and delaying a WU from completion.
So this weekend, I roll back to Win 7. Win 10 is beginning to look like another 'strange child' from the M$ misfit hive.
Here is the event record of the lockup, four critical errors..
Log Name: System
Source: Service Control Manager
Date: 9/24/2015 12:12:38 AM
Event ID: 7031
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: P4TWR4
Description:
The Sync Host_Session3 service terminated unexpectedly. It has done this 1 time(s). The following corrective action will be taken in 10000 milliseconds: Restart the service.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Service Control Manager" Guid="{555908d1-a6d7-4695-8e1e-26931d2012f4}" EventSourceName="Service Control Manager" />
<EventID Qualifiers="49152">7031</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x8080000000000000</Keywords>
<TimeCreated SystemTime="2015-09-24T04:12:38.132330900Z" />
<EventRecordID>2249</EventRecordID>
<Correlation />
<Execution ProcessID="968" ThreadID="5924" />
<Channel>System</Channel>
<Computer>P4TWR4</Computer>
<Security />
</System>
<EventData>
<Data Name="param1">Sync Host_Session3</Data>
<Data Name="param2">1</Data>
<Data Name="param3">10000</Data>
<Data Name="param4">1</Data>
<Data Name="param5">Restart the service</Data>
<Binary>4F006E006500530079006E0063005300760063005F00530065007300730069006F006E0033000000</Binary>
</EventData>
</Event>
Log Name: System
Source: Microsoft-Windows-DistributedCOM
Date: 9/24/2015 12:12:39 AM
Event ID: 10010
Task Category: None
Level: Error
Keywords: Classic
User: P4TWR4\****
Computer: P4TWR4
Description:
The server CortanaUI.AppXd4tad4d57t4wtdbnnmb8v2xtzym8c1n8.mca did not register with DCOM within the required timeout.
Event Xml:
<System>
<Provider Name="Microsoft-Windows-DistributedCOM" Guid="{1B562E86-B7AA-4131-BADC-B6F3A001407E}" EventSourceName="DCOM" />
<EventID Qualifiers="0">10010</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2015-09-24T04:12:39.351078700Z" />
<EventRecordID>2250</EventRecordID>
<Correlation />
<Execution ProcessID="1160" ThreadID="5088" />
<Security UserID="S-1-5-21-3146783824-3998642876-2413362134-1000" />
</System>
<EventData>
<Data Name="param1">CortanaUI.AppXd4tad4d57t4wtdbnnmb8v2xtzym8c1n8.mca</Data>
</EventData>
</Event>
Log Name: Application
Source: Microsoft-Windows-Immersive-Shell
Event ID: 5973
Task Category: (5973)
Level: Error
Keywords:
User: P4TWR4\****
Computer: P4TWR4
Description:
Activation of app Microsoft.Windows.Cortana_cw5n1h2txyewy!CortanaUI failed with error: The app didn't start. See the Microsoft-Windows-TWinUI/Operational log for additional information.
Event Xml:
<System>
<Provider Name="Microsoft-Windows-Immersive-Shell" Guid="{315A8872-923E-4EA2-9889-33CD4754BF64}" />
<EventID>5973</EventID>
<Level>2</Level>
<Task>5973</Task>
<Opcode>0</Opcode>
<Keywords>0x2000000000000000</Keywords>
<TimeCreated SystemTime="2015-09-24T04:12:39.358740000Z" />
<EventRecordID>1657</EventRecordID>
<Correlation />
<Execution ProcessID="328" ThreadID="4392" />
<Channel>Application</Channel>
</System>
<EventData>
<Data Name="AppId">Microsoft.Windows.Cortana_cw5n1h2txyewy!CortanaUI</Data>
<Data Name="ErrorCode">-2144927141</Data>
</EventData>
</Event>
Log Name: Microsoft-Windows-AppModel-Runtime/Admin
Source: Microsoft-Windows-AppModel-Runtime
Date: 9/24/2015 8:14:25 AM
Event ID: 69
Task Category: None
Level: Error
Keywords: (70368744177664),Process
User: SYSTEM
Computer: P4TWR4
Description:
Failed with 0x490 modifying AppModel Runtime status for package Microsoft.Windows.Photos_15.922.11070.0_x86__8wekyb3d8bbwe for user P4TWR4\**** (current status = 0x0, desired status = 0x20).
Event Xml:
<System>
<Provider Name="Microsoft-Windows-AppModel-Runtime" Guid="{F1EF270A-0D32-4352-BA52-DBAB41E1D859}" />
<EventID>69</EventID>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x2000400000000001</Keywords>
<TimeCreated SystemTime="2015-09-24T12:14:25.571810000Z" />
<EventRecordID>293</EventRecordID>
<Correlation ActivityID="{7C230279-F4D6-0000-1C4F-237CD6F4D001}" />
<Execution ProcessID="5000" ThreadID="1216" />
<Channel>Microsoft-Windows-AppModel-Runtime/Admin</Channel>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="ErrorCode">1168</Data>
<Data Name="PackageFullName">Microsoft.Windows.Photos_15.922.11070.0_x86__8wekyb3d8bbwe</Data>
<Data Name="User">S-1-5-21-3146783824-3998642876-2413362134-1000</Data>
<Data Name="DesiredStatus">32</Data>
<Data Name="CurrentStatus">0</Data>
</EventData>
</Event>
Date: 9/24/2015 8:15:46 AM
Event ID: 69
Task Category: None
Level: Error
User: SYSTEM
Computer: P4TWR4
Description:
Failed with 0x490 modifying AppModel Runtime status for package Microsoft.ZuneVideo_3.6.13251.0_x86__8wekyb3d8bbwe for user S-1-5-21-3146783824-3998642876-2413362134-1000 (current status = 0x0, desired status = 0x20).
Event Xml:
<System>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2015-09-24T12:15:46.572400900Z" />
<EventRecordID>296</EventRecordID>
<Correlation ActivityID="{7C230279-F4D6-0000-9A50-237CD6F4D001}" />
<Execution ProcessID="5000" ThreadID="5836" />
</System>
<EventData>
<Data Name="PackageFullName">Microsoft.ZuneVideo_3.6.13251.0_x86__8wekyb3d8bbwe</Data>
</EventData>
</Event>
PreviousNext
Return to Operating Systems
