It is currently Mon Jun 17, 2019 7:54 pm
 Post subject: SOLVED o/s systems
PostPosted: Thu Jul 31, 2014 3:38 pm
how to tell what system is installed in the laptop using the key under the laptop
working on another pavilian dv7-1130 it has win 7 64 bit but the bios says it should be vista but no version of vista
orrrr how to get the win 7 key to reactivate the o/s with this laptop i know i can download a tool for this but was wondering if i could just go through the system to retrieve it
virus in this and he wants it formatted and reloaded
K8n-NEO2 platium,AwardBIOS v6.00PG,AMD Athlon(tm) 64 Processor 4000+ Socket 939,ati radeon 9800 xt 256 agp ,windows XP w/service pack 2,2 G`s ram ddr 3200,running dual monitors
 Post subject: Re: SOLVED o/s systems
PostPosted: Fri Aug 01, 2014 10:53 am
The COA key for Windows is deeply hidden in the Registry. Here is a trick on how to find it..
http://www.ehow.com/how_8245239_windows ... ey-pc.html
PostPosted: Fri Aug 01, 2014 5:31 pm
thanks i found a free program to find all keys it even found the quickens 2013 pro keys
now i have to find a way to install the o/s the dvd-rom wont read the dvd so i made a bootable hdd and coping the dvd to that to boot to this laptop has a 2nd hdd spot to install a second hdd
PostPosted: Sat Aug 02, 2014 8:04 am
jellybean, right?
PostPosted: Sat Aug 02, 2014 11:08 am
That "magic jellybean" may contain spyware! Just did a DL of it, and AVG reports spyware found.
Copying the Win 7 install disk to a hard drive for use will not have all the files and drivers! Some files on the disk are hidden, and only for reference.
Windows 7 requires a DVD/CD drive that is compatible to the Microsoft AHCI driver (msahci.sys).
Some older DVD/CD units may not be.
If you get a USB Bluray optical drive, should be no problem. Some models start at under $100.00 USD.
PostPosted: Sat Aug 02, 2014 4:08 pm
evasive wrote:
jellybean, right?
nah i used Belarc Advisor worked real good i didnt install it on my puter i copied the exe file to the laptop ( who cares i formating the hdd anyway)
went here http://pcsupport.about.com/od/productke ... finder.htm
PostPosted: Sat Aug 02, 2014 4:09 pm
yea i found that out im still trying to install from the disk some times it will run some times it wont
PostPosted: Sat Aug 02, 2014 4:17 pm
this laptop is a pavilian dv7-1130us 64 bit came with vista but he had 7 home prem i dont have vista 64 bit but i do have 7 64 bit the window 7 dvd is kinda scratched so im going to bring it to the local game shop ( game stop ) and see if they will clean it up should only be about 5-10 bucks i can get it to start 1 out of ten times it never asks me for any drivers to install in the install process
PostPosted: Sun Aug 03, 2014 6:31 am
Be wary of the DVD polish.. It may be completely unusable afterwards. If you can create disc on a PC using an ISO burner like Imageburn (free, completely free), then burn it back to disc. I have lost too many games and films to a spotty oik in a 'games' shop over polishing...!!!
PostPosted: Sun Aug 03, 2014 4:32 pm
Anyone who attempts to "polish" an optical disk has to be careful and gentle.
The only compound suitable for use is 1,000 grit jeweler's rouge. And that followed by a specific wax compatible to the polycarbonate disk. Bon-Ami cleanser may tout that it "hasn't scratched yet" but don't try it on plastic!!!
The only safe way to attempt a polish is by spinning the disk slowly. A microfiber pad is fairly safe to use.
Those cleaning kits for polycarbonate light lenses on cars can destroy an optical disk!
