It is currently Wed Jan 16, 2019 12:37 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Apr 07, 2014 5:04 pm
Well sir ... looks like there was something in the BIOS setting I overlooked ... I got this from gigabyte today.
Dear customer,
Please try the following:
1) Go to Bios, press "Delete" during Bios start up screen
2) Go to"Power management"
3) Disable "PME Event wake up"
4) Press "F10" to save and exit.
Thank you.
The computer will now shutdown ... So we can happily mark this one as PROBLEM SOLVED. :-|
Main Rig_Intel i7 4770k@3.50
ECS H87H3-WM Ver1
16Gb DDR3 1600
Evga GTX 1050Ti GPU
WD100000 SATA 7200RPM
Seagate 1TB SATA 7200RPM
Corsair CX750M
Win7 Ultimate x64
Rig2_AMD FX8120
GIGABYTE GA-M68MT-S2 Mobo
4Gb DDR3 1600
ZOTAC GeForce GTX 550TI
Rosewill M650
Win7 64
PostPosted: Tue Apr 08, 2014 5:47 am
Sometimes, the solution is that works best is the simplest .. but we overlook it.
Nice the problem is solved.
