XP SP3
Postby c327 » Sun Dec 29, 2013 2:47 pm
Karlsweldt wrote:I make many double-postings also! The two ways it usually doesn't happen for me is when I hold the 'submit' button for more than a second, or if the cycle does not complete, then click back on the topic thread.. and there is the post.
Has to be glitchy software or flaky equipment with the hosting service.
Check the bottom right corner of the page.. you will see permissions for members. And if there is a small box with an X in it at the top right of your posting, you can delete your own post.
I also will continue to use Win XP for as long as my browser, antivirus and firewall program honor it. But eventually will have to go with a newer OS version.
OK will give that a try but I do think I tried holding down the submit button with no luck
c327
Postby c327 » Sun Dec 29, 2013 2:49 pm
On the second click I always get "You cannot make another post so soon after your last; please try again in a short while"
c327
Postby Karlsweldt » Mon Dec 30, 2013 6:44 am
c327 wrote:On the second click I always get "You cannot make another post so soon after your last; please try again in a short while"
Likely the anti-spammer 'guardian' for postings is a bit over-reactive.
Previous
Return to Operating Systems
