System reserved partition
Postby asassin' » Mon Jul 11, 2011 12:09 pm
How is the required size of this partition determined. I'm trying to rid my laptop of its restore partition and mutated the sizes by careless cloning.
Currently shuffling between a 160 and a 500GB drive. Am running 7Pro.
asassin'
Postby Hardware Junkie » Mon Jul 11, 2011 1:49 pm
It should only be 100MB and only about 30MB used. Microsoft has it set at that size.
If you partition the drive, prior to installing windows, then that system partition won't be there.
Return to Operating Systems
