try to remove xp dual boot os
Postby dragonle_2000 » Tue Dec 21, 2010 2:57 pm
hi guys, it been awhile since i come here for help. i had dual boot os in one hd with two different partition the first os is xp pro 32 and the second one is win7 ultimate 64. my question is can i remove the xp and keep the 7 for my primary os, even though i installed the xp first and used the easeus partition software to created a second partition for the 7 so how do i remove the xp and still make 7 bootable as a prinary os.
thanks guys
dragonle_2000
Postby bdub » Tue Dec 21, 2010 5:13 pm
is this in a laptop or a desktop? there's only one hdd in the system?
do you have a windows 7 OS dvd handy?
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
bdub
Postby Hardware Junkie » Tue Dec 21, 2010 8:56 pm
After all the files are deleted, you may just have to run this
http://support.microsoft.com/kb/927392
Postby dragonle_2000 » Wed Dec 22, 2010 5:14 am
thanks guys i got it now.
dragonle_2000
Postby bdub » Wed Dec 22, 2010 7:09 am
i was thinking along these lines...
http://windows7forums.com/windows-7-ins ... table.html
third post instructions to be done after booting into 7 and deleting the xp volume in disk management, then extendng the 7 volume to the beginning of the disk (if that is possible).
my main rig...
asrock 970 extreme3
antec neo he 650r
bdub
Return to Operating Systems
